99 Tracker. Right CV coupling pulled out of housing
Big Grin
4wd quit,, looked under front to see the right side joint pulled at least 1 1/2 out of housing. What holds this in differential ?? Questional damage to this point.
Nothing holds that side in (inside the front housing). It slips in, and then held in place once the housing is bolted down, or you reinstall your strut back on the control arm (depending on which way you removed it. Either is fine)
I’m willing to but you have a broken top mount on your front housing. It’s an aluminium flange with 2 bolts that is prone to cracking. Under heavy torque (usually reverse+4 low) the housing wants to move up/twist and it will break. Once it’s broken this same stress will cause it move around and your CV can pop out, you may also hear the driveshaft rubbing.
(01-21-2018, 03:47 AM)Perry Wrote: Nothing holds that side in (inside the front housing). It slips in, and then held in place once the housing is bolted down, or you reinstall your strut back on the control arm (depending on which way you removed it. Either is fine)
I checked the housing and mount,, the the three bolts involved with mount is tight with no cracks. Mounting is tight. I have found a reference to a circle clip on axle to retain in differential. Without disassembling I can freely push axle in an out of differential
see this page, it needs an axle kit
its busted for sure the drawings prove that.
next
we made this long ago, lots of contributors , and ways and means.
all the suzuki Cir-clips (snap rings are in the drawing) im guessing part 11 failed?
http://www.fixkick.com/axles/Pan-drop/pandrop.html
no photos of damage so only wild guessing by me., sorry
i can promise, once pulled, you go,,,all this failed, keep open mind, let evidence tell you.
[attachment=738]
(01-21-2018, 09:27 AM)fixkick Wrote: i can promise, once pulled, you go,,,all this failed, keep open mind, let evidence tell you.
I think it be 11.. I got a screenshot attached (not my part) of the shaft assembly of a 99 that moves freely in an out
The illustration or me could be different
[attachment=739]The pointer at cir- clip is what is needed I b guessing— now just WTH does s person find just the clip? Part number unknown. Family matters come first, back n a few days
UPDATE: Drained differential, inspection of lube produced no metal grindings,, fished out of case a few pieces which were remenants of cir-clip. Project on hold until weather warms. So far to find clip at part stores and GM has been futile. Over & Out
finding circlips is not easy. metric
most folks buy whole axle kit and do the whole thing. (after all the labor, not wanting second play ,soon)
but you might get lucky,.
the rings are (snap) are very tough case hardened spring steel (no beer can metal as sold from jokers in China)
