91 5 speed leek
Tongue
Tomorrow I'm going to look AGAIN for the leak. I have the NAPA Premium GL3-4-5 ready to go in again, but you make mention of some rubber PLUGS? that fall out? is there a picture of the
outside of the trans where i can see?
it is leaking and I do NOT want to run it low....Tongue
yes, up top front , not easy to reach, at all
http://www.fixkick.com/tranny/plugs.JPG
glued in with contact cement.
make sure the dizzy and its base dont leak, seen as wet oil on the bell housing.
(01-05-2015, 09:52 PM)fixkick Wrote: , not easy to reach, at all
haha you are correct !!
NOT EASY to reach. understatement HAAAAAA well I inserted a SILICONE plug AKA powder coat plug.. hope it slows down the leek...
as I am not about to drop the trans (AGAIN) to plug it!!!
but the leak is on the LF side.. the PLUG WAS GONE
the RH side OK
maybe I will CUT the floor to access this plug????
the RH side OK
id blast the hole with carb cleaner, and long tube
then pack it in RTV with my finger.
they are a pain theses plugs)
yes indeed
I used a mirror and found it right away.. NO PLUG. (MISSING)
left side only rh side looks good ??
I DON'T SEE A RH PLUG???
inserted powder coat plug pressed in and seems tight... \
I will keep looking at this leak..
put in 3+quarts of NAPA premium
