03-14-2017, 03:31 PM
I have a 1999 Chevrolet Tracker 2DR 2.0 2wd. I was getting the front tires replaced and one of the wheel studs is spinning with the lug nut on it and they couldn't remove that wheel.
I'm planning on working on removing that stud and lug nut but am worried that I will need a whole new wheel hub instead of just a wheel stud (planning for the worse). When looking for a replacement wheel hub I couldn't find one. No one seems to make them for a 99.
I noticed that I could get one for a 2001 but was wondering if anything is different? It appears the wheel bearings and seals are the same part #'s for both years, as are the spindles. The bolt patterns appear identical as well along with the ABS sensor #'s. The only real thing I can think of is because the 01 appear to be a full assembly with bearings and all.
Does anyone have any experience or know of any issues with using a 01 hub on a 99 before I try it out?
Thanks!
Thanks!
