on a perfect running engine and idle controls work right, and idle control ISC is working
and you set the duty to 50% (using the bleed screw)
if the TPS idle switch is not closed at 0vdc there will be no idle controls.
The ECU must not be stuck in limp-home mode. ( no CEL codes stored or worse live errors)
The ISC must not be bad , stuck or jammed, or , leaking air closed or dead coil inside.
No huge illegal air leaks.
the bleed as set to 50 % dutycycle on the coil of the ISC, using scope or duty meter, 180f coolant is hot not 140f ever. the IAC closes at 150f so, that must happen first.
i made this drawing that shows all parts related to idle
![[Image: freshair-map.jpg]](https://fixkick.com/IDLE-AIR/more-photos/freshair-map.jpg)
the scope here is wrong, cold engine but the hot engine we turn the bleed until the ISC signal is 50/50 , high only 1/2 the time, 200 times second it pulses
![[Image: iac-wave1w.jpg]](https://fixkick.com/IDLE-AIR/Slide_Show/images/iac-wave1w.jpg)
vertical scale above is 5vdc per division, the alternator is active ad 14.7vdc so looks like 3 division at 15v. the IAS is Pulse width modulated, PWM.
