Threads: 2
Hello everyone!
I have a 1990 Geo tracker M/T 4X4. I have a new fuel pump, new injector, 2 rebuilt ECM's for 89/90 and get no fuel from pump. I checked the injector with a noid light and it works fine. I know ECM's 91+ and different but I plugged it in anyway. When I plug it in and turn the key, I get a working fuel pump. It actually comes on for about 3 seconds. When I plug the correct ECM back in, turn key on, the fuel pump will bump for a fraction of a second...then nothing. I can crank and crank but...nothing. If I pour fuel in the throttle body, it will run all day long. Any positive feedback would be much appreciated.
Thanks
Threads: 2
06-13-2014, 08:26 AM
(This post was last modified: 06-13-2014, 08:28 AM by whistle80.)
Thank you for all of the information thus far! The only reason I have a 91 ECM is because I was planning on changing things over from 90 to 91 because of the aforementioned issues. I have a 91 intake manifold, distributor, coil, partial wiring harness, and ecm. I was just thinking that this could eliminate my problem. But I just don't want to give up on the 90 stuff. I just feel that it is something simple and I must be over looking it.
I will check out the wiring from the corrected diagram within the next day or so.
Threads: 2
Yes, I have a 2 door.
I would love to know the cranking voltage at each pin of the main relay.
I will test everything this weekend and report back.
06-14-2014, 12:22 AM
(This post was last modified: 06-16-2014, 02:46 AM by fixkick.)
the voltages are all there.
but cranking voltage can be 10 to12v.
what ever the battery is , cranking the pump will be, that or 0.5v less. so say 9.5v, in Alaska.
here in texas its 11vdc min.
just check battery voltage before and during cranking to see what she does.
then go to the rear tail light and check the pink wire.
if fuel pressure is at spec. all this is moot.
Threads: 2
06-14-2014, 01:51 AM
(This post was last modified: 06-14-2014, 01:52 AM by whistle80.)
Thank you, very helpful!!
What is the best way to test the TPS?
Threads: 2
06-15-2014, 06:42 AM
(This post was last modified: 06-15-2014, 06:43 AM by whistle80.)
Just a heads up:
The voltage to the pump was a little more than 10.xxV. My battery may be a little low due to cranking... The pump IS working by the way. I now have to figure out what is not working. As I crank it, I do smell fuel but it just doesn't want to even attempt to run. I borrowed another ecm and main relay...the same thing happens...NOTHING.
