1.8 into 2.0
I have acquired quite a fleet of 99/00 trackers. So of course all the engines are junk. Then i got a 98 sidekick with m.t.
question being, looking at these 2 they look the same except for intake. In looking around they share timing components, cylinder head has same casting.
So can i use the block and head and put it in a tracker.??
/thanks guys.
no, i want to go the other way. have a rust free tracker, bad engine. want to put the 1.8 sidekick in it.
if i use 2.0 intake, will that swap work?
thanks
REDUX,1
Quote:(edited)) have nice 99/2000 trackers dead motors. J20.
so i have running 1998 Sidekick (SPORTS) J18, but is rust bucket , (A sport is a wide frame car same os the 99s+)
so swap the long blocks, whats hard? there? taller head that's it. the stock 99/00 EFI will have no issues, with 200cc loss. like having a throttle stop.
you are right the look the same,
they mostly are, but j18 is shorter stroke, engine, same basic engine, (form factor, or family) same mounts.
same bell, same pilot shaft, , ill look that up just in case.
the J18 trans has the same larger fly pilot bearing (I.D)
Users browsing this thread: 3 Guest(s)
