1.8 into 2.0 - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1.8 into 2.0 (/thread-1-8-into-2-0) |
1.8 into 2.0 - advantage - 10-20-2015 I have acquired quite a fleet of 99/00 trackers. So of course all the engines are junk. Then i got a 98 sidekick with m.t. question being, looking at these 2 they look the same except for intake. In looking around they share timing components, cylinder head has same casting. So can i use the block and head and put it in a tracker.?? /thanks guys. RE: 1.8 into 2.0 - advantage - 10-23-2015 no, i want to go the other way. have a rust free tracker, bad engine. want to put the 1.8 sidekick in it. if i use 2.0 intake, will that swap work? thanks RE: 1.8 into 2.0 - fixkick - 10-23-2015 REDUX,1 Quote:(edited)) have nice 99/2000 trackers dead motors. J20.so swap the long blocks, whats hard? there? taller head that's it. the stock 99/00 EFI will have no issues, with 200cc loss. like having a throttle stop. you are right the look the same, they mostly are, but j18 is shorter stroke, engine, same basic engine, (form factor, or family) same mounts. RE: 1.8 into 2.0 - fixkick - 10-23-2015 same bell, same pilot shaft, , ill look that up just in case. the J18 trans has the same larger fly pilot bearing (I.D) |
