11-08-2017, 11:30 AM
I recently replaced the TV Cable on my 4sp (03-72LE\A44DE) Tranny.
I had to order the cable from Suzuki in Japan. It came with a little stopper that slips over the inner cable & i imagine is supposed to be crimped onto the inner cable somewhere...
According to the FSM the TV Cable adjustment should be based on that little stopper, but the stopper could be anywhere on the cable. So it does not make any sense to me.
I have tried the following procedure: Have throttle pedal fully depressed, & set the adjustment\locknut so that the inner cable is fully pulled out. when throttle is wide open.
When i have it like this it engages into R or D roughly (with a clunk sound) Also when the tranny shifts down from 2nd to 1st gear there is a clunk sound...
If i disconnect the cable from the throttle cam it shifts smoothly (without any clunking sound)
Could someone explain to me in a bit more detail what is the proper adjustment method ?
Thank You !
Thank You !
