did you open the rear door first. on some models the screws are only visable when the door is open
that chamber behind the rear tail lamps, no human can go, ever.
so how else would one get there?, answer, screws there.
the would lens assembly is ONE PIECE, backups/tailpark/turns Sigs/brakes, are all one piece.
the rear of it has twist of sockets, but can never be reached unless the whole assemble is removed.
the first years are like this.
see this photo , see those, plastic inserts on the bottom edge in the steel body
those are where the screws were fitted, im doing that , there.
my hand
one has to bend over and look , standing, maybe not be possible to see.
ill send the free GM book next. (as in Geo Tracker 93, same body)
1993 suzuki sidekick, located in USA right? made in canada CAMI plant vin starts with
a "2CN" is CAMI made and the C = CAMI made. 2= Canada.
right?
VIN starts with J means its made in JAPAN,
