Fixkick master index...Version 1
Suzuki Part Number Reference
http://www.fme-cat.com/Application.aspx?...ngine&ga=Y
G16 Engine Parts Exploded View
https://monsterfactoryparts.com/parts/19...CallOut=28
Pulling 16v Head
http://www.fixkick.com/engine/head-pull/...cam-locker
Depressurizing the fuel system the easy way.
http://www.fixkick.com/INJECTORS/depressure.html
Windshield Wiper Troubleshooting
http://www.fixkick.com/wipe-wash/index.html
Engine Issues
http://www.fixkick.com/index1.html
Tune Up
http://www.fixkick.com/IGN_timing/tune-ups.html
Belts
http://www.fixkick.com/belts.html
Timing Belt
http://www.fixkick.com/t-belt/tbelt-index.html
Suzuki TSB on Timing Belt
http://www.fixkick.com/All-Pdfs/TSB/89-96crank-bolt.pdf
Repairing Damaged Crank Key
Bad and Repaired Crank Cogs and Snouts
http://www.fixkick.com/t-belt/snouts/html/image_1.html
Locking the Crank in place
http://www.fixkick.com/engine/myclutch/f...locks.html
EGR Thermoprobes
http://www.fixkick.com/EGR-Gen2a.html#thermoprobe
Setting Valve Lash
http://www.fixkick.com/t-belt/LASH/Lash16v.html
Repairing a damaged Key
Dash Lamps
http://www.fixkick.com/buy-parts.html#Bulbs
Removing the Dash Cluster
http://www.fixkick.com/power-elect/clust...r-pull.pdf
Pulling the Tranny
http://www.fixkick.com/tranny/clutch/new...howto.html
Hard to Find Parts
Torque Specs
http://www.fixkick.com/specs/torque1.html
Adjusting Belts
Fuel System Tests
Engine cranks and will not start
http://www.fixkick.com/nostart-flow/nost..._ways.html
Poor MPG
http://www.fixkick.com/MPG.html
Engine making noise
http://www.fixkick.com/NOISE.html
Wiring a trailer light
http://www.fixkick.com/trailer-wiring/trailer.html
Idle Speeds are wrong
http://www.fixkick.com/IDLE-AIR/idle-index-home.html
Fixing Idle Problems
Finding Air Leaks
http://www.fixkick.com/IDLE-AIR/pure-leaks.html
Someone messed with idle stop screw
http://www.fixkick.com/fresh-air/screwed-again.html
ECU Capacitor Leak Issue Causing no start
ECU Clicking Issue
http://www.fixkick.com/ECU/clicking/clicking.html
Wheel Bearings
http://www.fixkick.com/hubs/FW_BEARINGS.html
Dropping the Oil Pan on 4x4
http://www.fixkick.com/axles/Pan-drop/pandrop.html#cv
thanks
my main page is indexed by systems functions, just like FSM's are.
and the free find , that and advanced search can find anything. unrestricted.
the free find , site index has more.
not only that , its not restricting to greater than 3 word searches, like other sites. and cant find ECT fore example. you can search this, "1"
my pages are simple white pages, no black backgrounds and can be printed. easy.
see the search box. see those 3 blue links there.
index, sitemap and advanced
the first show every word used, in 600 to 1000 pages, A to Z, even omega for ohms is indexed. by word.
the site map shows major indexed topic pages.
the last is the advanced search
and last my search box.
not bad for free, huh?
not only that you can search my site end to end using google SITE search
here is one example of that.
format
Search
