Anti theft system?
Is there any inexpensive way to install an anti-theft system? Switch on the fuel pump etc?
thanks,
sure that is all I have, just a fuel pump wire.
hid the switch well. they will never find it.
one trick is a hidden magnetic switch.
just a hole somewhere, in a panel or carpet. hidden
you insert a mag key and bam the pump is alive.
also at air port parking , remove the rotor from dizzy
ive parked for 30 days in air ports. so....
fixkick, do you have a source for the switch you are using? Also, did you use a relay or does your switch handle the amperage of a fuel pump?
thnkx. Good tip on airport storage!!
the pump sucks 4amps, normally, or up to 10amps, overloaded. (filter packed)
those switches are hard to find, ill dig that up.
