(04-26-2021, 06:18 AM)Hoopt Wrote: Trying to get the 97 sport with auto transmission road inspected. I don't have tail lights, back-up lights or tag lights. I have inspected, replaced fuses as I find them. It seems that this must be a rear harness or some cluster that is out.
I noticed two items under the dash,
1) a 4 wire plug is not connected. Looks like it maybe should plug into a switch. A white plug, receptacle. (wire colors
2) a single wire is hanging with a single wire plug to wire is not connected. It is orange w/ black or blue hash. I don't see a wire to connect with it. This looks to be factory installed.
hash marks are actually dots, and are market codes, what matters on wires is main color and the strip.
It looks like someone may have done some re-wiring in the not so long past.
i see what looks like two fusible links under the dash that look intact. (REAR GLASS DEFROST IS AN OPTION IF NOT OPTED YOU SEE EMPTY CONNECTORS)
Not sure where to go, except start from the rear and see if I can trace them back.
Thanks for your help.
HoopT
welcome Hoopt (j18 sport)
do THE HEAD LAMPS WORK RIGHT, ? AND ALL PARKING LAMPS FRONT AND REAR(sure rears tails/parks are dead sure)
do brake lamps fail? rear?
this car and all like it it have over 20 harnesses. and all have options not used, leaving unused connectors, vast.
that matters is the exact locations of any connector and even more wire colors tell me what they every one not black color has a purpose easy to look up in the schematic.
on all cars fues are first. the cab box and the right front fender box all fuse not blown or missing, named appropriate.
on the rear of any old car we look for trailer hitch, installs done wrong, for sure behind left rear tail lamp, harness rear is on left side of body and behind rear bumper
tail lamps are PaRKING lamps (another name) but means front parks must glow to, in park, and HL on, does it>? front too.
does this car have DRL option ,daylight running lamps ? as seen on canada cars all. (KEY ON HAND BRAKE RELEASED BINGO DAY LAMPS GLOW ALL)
this DRL loves to fail and kills lighting.
backup laps run off a fuse and the PRNDL switch in the 4speed box, in Reverse.
he tag lamp are just parking lamps so sure it is dead if all 4 or more parking lamps are dead even side of car parking lamps if opted new.
the only way fix cars and for sure electric (fuse good, and DRL not there , and make sure the cluster combo switch stalk (off/park/HL) cable on steering column is
not broken.)
is with a schematic, called body schematic.
one way is to pick parking wires and test them. using a voltmeter, for 12vdc. in park, even at the park switch STALK) R/Y wires (red/yellow) to 10 lamps.
facts, below, j18 (im online at car books, Factory manuals. reading)
fuse 17 runs backup lamps.
park lamps path front to rear
Fuse 11 not blown. (front engine bay box right fender, labled tail dome. there)
Headlamp relay 2 not bad or missing, do you need help finding relays?
combo wire R/BL park not bad or switch bad, this switch turns on relay2 above.
relay output pin 4 , R/y runs 10 parking lamps, are all 10 dead? front rear and sides. and tag lamps.
this is how park works, just 3 parts, the make Relay 2 work. Not counting 10 dead lamps impossible to all fail, just them.
fuse , relay and park combo stalk lever switch 3 things good. and park works, fuses are always first fuse 11 here.
