10-21-2020, 03:00 AM
I have 1996 sidekick JLX Sport 1.8L 4x4 Automatic trans. 188k miles and counting
Ok where to start the daytime running lights work just fine , but when I turn on the headlights I get nothing no low beams no high beams and it turns off the daytime running lamps. also the daytime running lamps stay on when I switch on the park lights and I can flash the highbeams. Same is also true when I have the headlight switch in the off position. The Problem only presents itself when I switch the headlights on. Battery and Headlights recently changed so I know they are good. I need to know if this is a fuse problem a switch problem or a relay problem. Blinkers and hazards work fine so I am confused at this point.
