Hi I am trying to get my Sidekick to pass a smog check in California. There is a vacuum valve which is broken (with blue connector in picture below). Does anyone know which this valve is and where I could get a new one?
i have no idea if any 3rd party maker , makes this part, that would take lots of research , but you do have p/n real. and is not cheap.
(02-23-2019, 03:47 AM)Nadolski Wrote: Hi I am trying to get my Sidekick to pass a smog check in California. There is a vacuum valve which is broken (with blue connector in picture below). Does anyone know which this valve is and where I could get a new one?
the vsv has 2 nipples, suck side plenum and output to EGR
it has on top a filter that when the valve is deEnerized it vent the EGR nipple to the filter size letting the egr not get vacuum locked.
and 1 connector with 2 pins.
that is all.
the filter keeps dirt for jamming the internal valve.
OR as any good store asks what is your vin number
leave out the last 3 digits for privacy only those are serial end.
the vin code for carb car shows 1.3L code. or 1.6L code.
the carb car is called JA car.
the photo in post 1 is TBI 1.6L with 2 vsv side by side
the carb car has a pile of solenoids in the carb
and carb car one 3 way valve EGR on the engine side, and not a pair nor same as TBI
if only the photo was back a foot , ends mystery car.
