Carburetored 1989 Sidekick vacuum Valve - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Carburetored 1989 Sidekick vacuum Valve (/thread-carburetored-1989-sidekick-vacuum-valve) |
Carburetored 1989 Sidekick vacuum Valve - Nadolski - 02-23-2019 Hi I am trying to get my Sidekick to pass a smog check in California. There is a vacuum valve which is broken (with blue connector in picture below). Does anyone know which this valve is and where I could get a new one? RE: Carburetored 1989 Sidekick vacuum Valve - fixkick - 02-23-2019 sure that is a vsv, vacuum solenoid valve. and is custom to this car and sold by suzuki. the blue one is. EGR http://fixkick.com/sensors/89/89-vacl-map1.jpg id 11 here, line 34. see it> now the p/n suzuki not GM/geo 18117-61a00 "Suzuki Genuine Factory Part Part Number: 1811761A00 " https://www.suzukicarparts.com/parts/1995/Suzuki/Sidekick/JS/index.cfm?action=partDetail§ion=EMISSION%20SYSTEM&group=EMISSION%20SYSTEM&subgroup=EGR%20SYSTEM&component=SOLENOID%20VALVE&partnumber=1811761A00&vehicleid=187784&siteid=214820 i have no idea if any 3rd party maker , makes this part, that would take lots of research , but you do have p/n real. and is not cheap. (02-23-2019, 03:47 AM)Nadolski Wrote: Hi I am trying to get my Sidekick to pass a smog check in California. There is a vacuum valve which is broken (with blue connector in picture below). Does anyone know which this valve is and where I could get a new one? RE: Carburetored 1989 Sidekick vacuum Valve - Nadolski - 02-23-2019 Okay thank you very much for the help! Do you have a picture of a good VSV? The top of mine is broken off so I’m not sure what is missing. RE: Carburetored 1989 Sidekick vacuum Valve - fixkick - 02-23-2019 sure, its used on all sidekick in usa, 1989 to 1995 when the 8valve engine was banned in USA forever and in calif 1 year sooner. sure. does this work? http://www.fixkick.com/sensors/vsv.html RE: Carburetored 1989 Sidekick vacuum Valve - fixkick - 02-23-2019 the vsv has 2 nipples, suck side plenum and output to EGR it has on top a filter that when the valve is deEnerized it vent the EGR nipple to the filter size letting the egr not get vacuum locked. and 1 connector with 2 pins. that is all. the filter keeps dirt for jamming the internal valve. good luck to you !!! RE: Carburetored 1989 Sidekick vacuum Valve - fixkick - 02-23-2019 im sorry the 89 cam in 1.3 liter carb. and in 1989 1.6 liter TBI which is it. if carb real , then let me get those drawing Up I have them. RE: Carburetored 1989 Sidekick vacuum Valve - fixkick - 02-23-2019 OR as any good store asks what is your vin number leave out the last 3 digits for privacy only those are serial end. the vin code for carb car shows 1.3L code. or 1.6L code. RE: Carburetored 1989 Sidekick vacuum Valve - Nadolski - 02-23-2019 Thanks for the help on this! RE: Carburetored 1989 Sidekick vacuum Valve - Nadolski - 02-23-2019 It’s the 1.3 liter carburetor model RE: Carburetored 1989 Sidekick vacuum Valve - fixkick - 02-23-2019 the carb car is called JA car. the photo in post 1 is TBI 1.6L with 2 vsv side by side the carb car has a pile of solenoids in the carb and carb car one 3 way valve EGR on the engine side, and not a pair nor same as TBI if only the photo was back a foot , ends mystery car. |
