P0113 code - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: P0113 code (/thread-p0113-code) |
P0113 code - 98TrackerMan - 10-23-2015 Howdy All. got a "service eng soon" light- got out the OBDII and came up with code P0113,intake air temp sensor 1 circuit high- what should i do about this one? Had to get to work so didn't do anything yet. Get part & Just replace it? where is it located? I have a 1998 Chevy tracker 4x4,4Dr 98K miles Just was going to take it in for State Inspection too this wknd. Insp is up end of Oct. What a bummer. Thanks for any assistance 98TrackerMan RE: P0113 code - fixkick - 10-23-2015 the IAT is unplugged, at the air cleaner. base box. G16, the J18 sport engine, is on lid of air cleaner box. both engine in same 6 sq-in domain. most times, last air cleaner swap, makes this connector fall off. or was removed and forgotten. this is the lest important sensor. it only does fine , adjustments to maf readings already temperature corrected. see air clean , back side is IAT , in rubber grommet RE: P0113 code - 98TrackerMan - 10-23-2015 Just cked in, Ok I'll check it out. was at the ur website in A.M. and couldn't peruse because of time, so to the Forum I went- never disappointed here! As always thanks for your help. Have a Great wknd! 98TrackerMan RE: P0113 code - fixkick - 10-23-2015 you to, and glad to help you.! |
