EGR Valve Probes still available? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: EGR Valve Probes still available? (/thread-egr-valve-probes-still-available) |
EGR Valve Probes still available? - cosmic_splatter - 09-15-2014 Fixkick, If you purchase one of these EGR valves on Ebay, can you still buy the electrical probe for it? I haven't seen the probe sold. http://www.ebay.com/itm/EGR-Valve-ACDelco-GM-Original-Equipment-214-902-/351046138482?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1995|Make%3AGeo|Model%3ATracker|Submodel%3ABase|Engine+-+Liter_Display%3A1.6L&hash=item51bbfafa72&vxp=mtr John Not sure if this aftermarket fits.... http://www.ebay.com/itm/Standard-Motor-Products-ETS13-Temperature-Sensor-/130928526290?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AGeo|Model%3ATracker&hash=item1e7bf2c3d2&vxp=mtr This maybe suzuki part num? http://lehmansuzukipartsonline.com/parts/1995/Suzuki/Sidekick/index.cfm?action=partDetail§ion=EMISSION%20SYSTEM&group=EMISSION%20SYSTEM&subgroup=EGR%20SYSTEM&component=THERMO%20SENSOR&partnumber=1821656B00&vehicleid=187784&siteid=216897 RE: EGR Valve Probes still available? - fixkick - 09-15-2014 most used probes are good. it just a resistor, and crude.. just take out the old one. (heat casing hot, then take it off it tight. (for 80 to 160 bucks , i even split the old casing, to free it.) the test is easy, for ohms. sure they are available but very expensive all 89-95 are same. pn usa, canada and Caribbean 18216-56b00 did you look at rockauto first? bingo , 3 makers +1 suzuki = 4 GM shows, Discontinued . http://www.rockauto.com/catalog/raframecatalog.php?carcode=1271450&parttype=5093 RE: EGR Valve Probes still available? - cosmic_splatter - 09-19-2014 Fixkick What's the proper way to seal the probe to the egr valve? Should some sorta compound be used or should it be threaded in dry? John RE: EGR Valve Probes still available? - fixkick - 09-19-2014 id use, antiseize on it so in the future,it might come one, some wont. |
