Brake Caliper Bolts...Very tough and rough looking.... - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Brake Caliper Bolts...Very tough and rough looking.... (/thread-brake-caliper-bolts-very-tough-and-rough-looking) |
Brake Caliper Bolts...Very tough and rough looking.... - cosmic_splatter - 08-30-2014 Fixkick, I changed the brake calipers on both sides of the car today. 3 of the 4 Caliper bolts had to be heated with propane torch to get them off. They must have been the original factory calipers and those bolts have never been removed. Luckily you get new threads on the new calipers! I re-used the factory caliper bolts since they don't give you these on replacement calipers. Is it possible to still get factory style caliper bolts? I believe they are M12 x 1.25mm pitch. I checked a few online suzuki places and I don't see them listed. Any thoughts? I probably should replace them next time I have the tire off. John RE: Brake Caliper Bolts...Very tough and rough looking.... - fixkick - 08-30-2014 yes, most online , fail to show all parts in stock on this old generation cars, even though they may have the parts. you need full parts listing. to find them. the size is easy but not the grade. not the guide pins. but actual calip. mounts 09100-12111 (2 door and 4door) same. that is the org. p/n they use new p/n now. so... (the names now show up wrong.0) http://www.lehmansuzukipartsonline.com/parts/1995/Suzuki/Sidekick/index.cfm?siteid=216897 09100 are bolts. never arms so.... I get my harder to find bolts here, or at Napa auto. http://www.boltdepot.com/Metric_hex_bolts.aspx class 10.9 (simular to grade 8 SAE) this will be strong enough. 1040 Mpa rating, (crazy strong.) http://www.boltdepot.com/Metric_tap_bolts_Zinc_plated_class_10.9_steel.aspx RE: Brake Caliper Bolts...Very tough and rough looking.... - cosmic_splatter - 08-30-2014 You are a genius! thank you! John |
