195 degree stat or stock?? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 195 degree stat or stock?? (/thread-195-degree-stat-or-stock) Pages:
195 degree stat or stock?? - barnbiketom - 11-04-2013 i got cold and the 180 wasn't doing it. I went to 195 and get a lot of heat now. all else is good.. just the extra 15 degrees makes this old guy happy.. but is there any bad result of a 195 that will happen?? maybe the motor will like hotter beter = more gas mileage ??? ![]() ![]() ![]() ![]() ![]() i have good flow thru the heater core, doors all working and good airflow in all positions, just when the weather is cold it wouldn't get ME WARM with a ragtop full of airleeks haahah RE: 195 degree stat or stock?? - fixkick - 11-04-2013 its good, all new cars run like this. it is ok. 1/2 mile more per gallon make EGR work and more mpg. stay warm ! RE: 195 degree stat or stock?? - gorkyb - 11-05-2013 Hello barnbiketom, I've been running 195F thermostat for a couple of years now without any issues (that seem related to the thermostat anyway) RE: 195 degree stat or stock?? - fixkick - 11-05-2013 me to since, 2005. it make the engine more efficient and radiator can cool better (Carnot laws) the fact is suzuki sells it as an option, i have the p/n. RE: 195 degree stat or stock?? - barnbiketom - 11-05-2013 the only thing that alarms me, is the smell and stench of burning off of all the 22 years worth of crap everywhere, but after a few days it is dimininishing. not that there are any leaks, but it just "SMELLED" hotter you know ??? all is good now!! thanks guys the Smurfmobile is good RE: 195 degree stat or stock?? - fixkick - 11-12-2013 12-15deg hotter but id bet the ECu now holds closed loop, and gets 28mpg. and when that happens all that old crap on the engine burns off, many old kicks , have not seen closed loop in 5years. it's now burning all the fuel. congrats ! RE: 195 degree stat or stock?? - barnbiketom - 11-17-2013 thanks for the congrats!!! yesterday i looked in front and saw coolant DRIPPING OOH NOOOOOOOOO it was merely a loose upper hose clamp. needless to say now they are ALL re-tightned.. cold weather brings out the worst huh RE: 195 degree stat or stock?? - fixkick - 11-17-2013 yes, let the system hit 12 to 14psi, and then look for leaks.. you car will be nice and warm this winter. cheers to you. RE: 195 degree stat or stock?? - barnbiketom - 11-18-2013 im 61 and will never be warm haaaaaaaaaaaaaaaaaa but it is much much better... thanks !! ![]() ![]() ):
RE: 195 degree stat or stock?? - fixkick - 11-18-2013 85F in texas ,yesterday... heheheheheheheh |
