2001 Chevy Tracker - Struts and Shocks - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 2001 Chevy Tracker - Struts and Shocks (/thread-2001-chevy-tracker-struts-and-shocks) |
2001 Chevy Tracker - Struts and Shocks - dhe - 02-08-2025 I think it's time to replace my shocks and struts. Can anyone tell me if any BilStein options would work, or other recommendations? RE: 2001 Chevy Tracker - Struts and Shocks - Akull - 02-15-2025 When I had a 1994 sidekick, I went with old man emu front struts, and pro-comps from a ford escape. But those were slightly longer than stock for a lift. RE: 2001 Chevy Tracker - Struts and Shocks - fixkick - 02-16-2025 (02-08-2025, 09:09 AM)dhe Wrote: I think it's time to replace my shocks and struts.not modified or lifted? stock wheels/tires. ? 2001 tracker, 2 door or 4? 2.0L or the V6? 2.5L V6, is a more heavy engine, up front... but seems ok, this. got ABS ? ( matters) front or rear or all 4? and lefts and rights and rears are 4 part numbers. as are ABS the autostore is no help? they sure can,.!! https://www.rockauto.com/en/catalog/chevrolet,2001,tracker,2.0l+l4,1371631,suspension,shock+/+strut,7556 did you look at rockauto.com first front struts. good this. KBY shows same struts both engines, to that is good. BilStein??? they said no. so read their Ecatalog yet./ makers web stite they show no TRACKERS 1994 cars are not 2001, for sure ABS missing 94. RE: 2001 Chevy Tracker - Struts and Shocks - dhe - 02-22-2025 BilStein so no. Ended up ordering KYB from RockAuto. Will report back, how it goes. RE: 2001 Chevy Tracker - Struts and Shocks - dhe - 02-26-2025 According to my mechanic, the KYB Shocks and Struts from Rock Auto worked fine. He found CV axel needed replaced 2001/140K. Went to drive to mechanic and the transmission cable gave way, but he got that going but recommended a new cable. +new pads on the front + rotors, the back brakes were done when the seals on the back axel started to leak last year. I should just buy a new Bronco!! Only thing stopping me is a lack of money. RE: 2001 Chevy Tracker - Struts and Shocks - dhe - 02-27-2025 Replacing the shock and struts made a huge deference (for the better). |
