1990 sidekick 1.6l 5spd died at stop light - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1990 sidekick 1.6l 5spd died at stop light (/thread-1990-sidekick-1-6l-5spd-died-at-stop-light) |
1990 sidekick 1.6l 5spd died at stop light - Skips - 08-31-2022 Car died in traffic on me, thought it was fuel pump! So I replaced that. And replaced the injector as I found one local. Im getting fuel to the TB, and have spark. Car will Start with starter fluid! Replaced caps in computer, as recommended By local Suzuki guy Found the NAG switch and am getting 12 while jumping diagnostic pin I’m not getting anything with a Noid at the fuel injector plug and and no movement on tach while cranking.. a little perplexed. Any help would be great! RE: 1990 sidekick 1.6l 5spd died at stop light - fixkick - 10-29-2022 (08-31-2022, 11:56 PM)Skips Wrote: Car died in traffic on me, thought it was fuel pump! So I replaced that. And replaced the injector as I found one local. Im getting fuel to the TB, and have spark. Car will Start with starter fluid! 1988 to 1995 USA years. which is yours, ???
NOT 88/90 ,uP is microprocessor in ECU,. I only traced this to IC10 https://fixkick.com/ECU/ECU-8v.html my 91 page shows the q101 .q102 true names of transistors. standared 2SB and 2SD japan maker.. by toshiba even the data sheet I found. 2SB is a Darlington transistor super beta part. safe buys on ebay for them.
