1997 Tracker - Temp Gauge on Cold - TrackerLux - 09-14-2020
New Tracker owner.
Loving all the info from the Trackick crew.
Driving the Tracker last night. I noted the temp coming up while on surface streets heading toward the freeway. As I was cruising on the freeway I looked at the fuel gauge and felt like it had gone down to much for the trip that I had done. Scanned the dash and noticed that the temp gauge was no longer in the middle of H and C but buried on Cold.
It was running smooth on the freeway and surface streets. There was one instance that I came to a stop and the needle on the temp gauge seemed to jump back to the middle and then quickly fell back to cold. Almost seemed like some sort of a vacuum issue? This only happened once in many stops.
Hoping the community can give me some repair steps. As my only thoughts are thermostat and or temp sending unit?
Thanks in advance!
RE: 1997 Tracker - Temp Gauge on Cold - fixkick - 09-14-2020
(09-14-2020, 04:07 AM)TrackerLux Wrote: New Tracker owner.
Thanks in advance! it is real simple this device (guage)
a gauge,
a wire (1)
and sensor.
if the othermeters works then power to the cluster is ok 12vdc ok.
the most common failure is the sensor is bad or the clip on the wire on the sensors is rusty. it is old so rust happens big time on old cars.
the sensor is on the thermostat housing, dead front pointing front. and 1 wire, if gauge id dead, wiggle that connector even use pliers to make it tighter.
here are the tests both hot and cold.
https://fixkick.com/sensors/tests/Guage-coolant-test.html
RE: 1997 Tracker - Temp Gauge on Cold - TrackerLux - 09-14-2020
(09-14-2020, 08:58 AM)fixkick Wrote: (09-14-2020, 04:07 AM)TrackerLux Wrote: New Tracker owner.
a gauge,
a wire (1)
and sensor.
Thank you for the reply FixKick. Really appreciate the time and effort you have put in to keeping these vehicles on the road.
I did take some pics but they were to big to upload. In taking pics for the forum - I checked that connection on that front sending unit. Just as you mentioned the connector that attaches to the blade failed. When I removed it to check for corrosion I found that it was already in several pieces. Totally annoying.
Sidebar - this Tracker has the timing set to 4pm. It runs decent but I will be using all your knowledge to set it back to stock.
(09-14-2020, 01:52 PM)TrackerLux Wrote: (09-14-2020, 08:58 AM)fixkick Wrote: (09-14-2020, 04:07 AM)TrackerLux Wrote: New Tracker owner.
a gauge,
a wire (1)
and sensor.
your welcome
these connectors have (had) zinc plating over brass on some, or over steal.
and when the zinc goes away ,time and wear and corrosion these fail first. most did already, or flaky. It uses just normal "FastON" there.
https://www.mouser.com/new/te-connectivity/te-312-faston-connectors/
the spark can be timed at any CAP post, the choice in the manual is to make it consistent, and in other pages of the FSM factory manual ,it uses this rotor position for checking valve latch and for setting cam belt timing, so is best set like this. (but not required)
if you look, inside the dizzy, cap off, and dust cover the CMP is seen cam sensor. this sensor as 4 huge lobes. (all 4 identical)
the ECU nor the Distrib, knows where #1 is , only you know and timing it correctly. 4 ways possible the harness will fight you at base for many of the 4 ways.
below is factory timed, and CCW is cam gear fixed, on MPI 4 injector engine.
I'd just drive it.
before messing here best be sure the timing freeze DLC jumper works correctly, ask.
if you have the 96 GM GEO FSM (REAL) watch out for these errors in just that manual. just that 1 book, Suzuki real books do not have this here, I checked.
https://fixkick.com/IGN_timing/error-galore.html
RE: 1997 Tracker - Temp Gauge on Cold - TrackerLux - 09-15-2020
(09-14-2020, 08:59 PM)fixkick Wrote: if you have the 96 GM GEO FSM (REAL) watch out for these errors in just that manual. just that 1 book, Suzuki real books do not have this here, I checked.
10/4 - I have been driving for a month with it timed in the 4 o'clock position.
But in looking at all the material here, I am planning to just do a major tune and get things back to factory spec. Timing belt, cap, rotor, water pump, dizzy seal, manifold cleanse (EGR ports), hoses, etc. I just want it to be dialed in so we can do some off road excursions!
