New Owner - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: New Owner (/thread-new-owner) |
RE: New Owner - Nonmilagno - 07-15-2020 There was a bad spot on the bolt threads and the hole (about 2 threads worth), don’t know what caused it. Looks like it will clean up pretty easily with a 12mm x 1.25 thread chaser. Having difficulty finding the bottom cog. Only place so far is an eBay listing from the Middle East. Still looking... RE: New Owner - Nonmilagno - 07-15-2020 Found the cog (12631-53B00) on Suzukiautomotiveparts.com for $46 shipping included. 17mm bolt is $11. No woodruff key listed on this site, may find elsewhere. RE: New Owner - Nonmilagno - 07-16-2020 Fixkick Camshaft timing belt cog removed, locating pin and corresponding slot on cog look perfect. However, I do want to replace the bolt. Do you have a part number? Can’t find it. Again, thanks for the help. RE: New Owner - fixkick - 07-16-2020 (07-16-2020, 06:08 AM)Nonmilagno Wrote: Fixkicksure on my cog wrecked page see the p/n table bottom of page here. https://fixkick.com/t-belt/damage/index.html 12619-53B01 92 up, 16valve. if any dealer has B02 up that means newer revision, no fear. that. RE: New Owner - Nonmilagno - 07-16-2020 Searched that number, isn’t that the crankshaft bolt? I need the camshaft bolt. RE: New Owner - fixkick - 07-16-2020 (07-16-2020, 07:40 AM)Nonmilagno Wrote: Searched that number, isn’t that the crankshaft bolt? I need the camshaft bolt.sorry my bad will send number in AM, early RE: New Owner - Nonmilagno - 07-16-2020 Thanks a lot, I really appreciate the help. RE: New Owner - fixkick - 07-16-2020 (07-16-2020, 11:42 AM)Nonmilagno Wrote: Thanks a lot, I really appreciate the help.there are 4 engines, 89-98? not sure which you have, G16 is the guess. and can be 8valve or 16v head, but seems to be same on all G16 1991 and up. cam bolt is 01550-12253 (my EPC clearly states, this) cam sprocket bolt. even used on 2003 Grandvitara G16b( 16v) and Esteem G16 too.99-02) suz says superseded by.? IDK 01550-1225A the drawings at suzuki skip this bolt, not seen at all in the drawing there. adding to the drama. https://www.amazon.com/Suzuki-Bolt-01550-1225A-New-Oem/dp/B01LZXDNO0 even suzuki gets confused here https://www.suzukiautomotiveparts.com/oem-parts/suzuki-suspension-cross-member-bolt-015501225a RE: New Owner - Nonmilagno - 07-16-2020 Thanks for the numbers, I’ll check it out. RE: New Owner - fixkick - 07-17-2020 (07-16-2020, 11:15 PM)Nonmilagno Wrote: Thanks for the numbers, I’ll check it out.you are very welcome and anytime, please ask. PS good luck on your build !! |
