'92 16v sidekick - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: '92 16v sidekick (/thread-92-16v-sidekick) Pages:
RE: '92 16v sidekick - fixkick - 07-11-2020 IC7 has purpose , ask it's only purpose to to keep IC17 and its transistor from blowing up , with simple wire shorts on TPS. on one PC the copper (PCB) traces to the IC7 were blown to hell, just B6 trace. RE: '92 16v sidekick - danstrayer2 - 02-19-2021 Fixkick et al----Seven months into this hot wire fix, all is well with this fix as described, 7000 miles so far, no further issues. I did go on Ebay and found a very small digital voltage regulator, adjustable, 1/2" x 3/4", which can replace or augment IC 6 (or IC7?) and provide 5 VDC to the TPS. Question for Fixkick: The diagnostic code set indicated the TPS failure, BUT...will the failure of IC6 to provide power to the TPS be shown as that same code? I am starting to suspect the TPS is OK, and it was the IC 6 failure which caused the TPS code, ( I think it's 21,22). Thoughts on this? Thank you in advance. RE: '92 16v sidekick - fixkick - 02-19-2021 (02-19-2021, 05:32 AM)danstrayer2 Wrote: Fixkick et al----Seven months into this hot wire fix, all is well with this fix as described, 7000 miles so far, no further issues. I did go on Ebay and found a very small digital voltage regulator, adjustable, 1/2" x 3/4", which can replace or augment IC 6 (or IC7?) and provide 5 VDC to the TPS.when the +5vdc refer, pin fails. sensors will go dead, and lie and then the diagnostic see that and reports even new sensors as bad. the +5vdc REF, is not ever optional. when 5v goes to 0v, the sensors go dead. for sure TPS, will show TP pin too low, fix +5v dead first, (only 2 causes, of that bad ECU or a sensor is shorted, (wiring is top reason for shorts) the ECU Is so dumb it does not check +5vref pin first. and make it a low number DTC error , sadly it only shows sensors dead, and only voltmeter tells the the real truth. here. cheers and good luck to you!!! |
