Identify connector, pls - heater valve? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Identify connector, pls - heater valve? (/thread-identify-connector-pls-heater-valve) |
Identify connector, pls - heater valve? - Jules - 05-11-2020 Can someone tell me what this connector is on the back of the engine (black with 3 pins)? It is in between the coolant outlet pipe and the heater core hose. Is it a heater valve switch? The reason I ask is that I'm building a 4x4 tube buggy and want to use the heater core as an extra radiator so I want to make sure coolant is circulating thru the core all the time. But, if there is a valve switch, then I need to make sure that switch is always open. RE: Identify connector, pls - heater valve? - Jules - 05-11-2020 Found it. Water temp sensor. http://catcar.info/suzuki/?lang=en&l=bWFya2V0SWQ9PXx8c3Q9PTYwfHxzdHM9PXsiMTAiOiJNYXJrZXQiLCIyMCI6IkFsbCBSZWdpb25zIiwiMzAiOiJHcmFuZCBWaXRhcmEiLCI0MCI6IlNRNDIwVy0zIiwiNTAiOiJDb29saW5nIiwiNjAiOiI2OSAtIFdBVEVSIEhPU0UgKFNRNDIwVykifXx8bW9kZWxJZD09MTd8fGVxdWlwbWVudElkPT0xNzMyMnx8cG9zRmlsdGVyPT1NT0RFTC9TUTQyMFd8fGdyb3VwSWQ9PTExNTB8fHN1Ymdyb3VwSWQ9PTYzNzk2 |
