problem with TPS sensor - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: problem with TPS sensor (/thread-problem-with-tps-sensor) |
problem with TPS sensor - javi2020 - 04-23-2020 Hello,I found a second-hand TPS sensor,since mine is in bad condition, the problem is that it belongs to a suzuki samurai but it is the same as the one I have installed, 4 same wires colors.would have some problem placing it on my vita,thanks a greeting RE: problem with TPS sensor - fixkick - 04-23-2020 (04-23-2020, 04:06 AM)javi2020 Wrote: Hello,I found a second-hand TPS sensor,since mine is in bad condition, the problem is that it belongs to a suzuki samurai but it is the same as the one I have installed, 4 same wires colors.would have some problem placing it on my vita,thanks a greetingif it bolts on and fits and the wires can be connected right IT WILL WORK TPS cracked inside or worn carbon path inside will not work . the wires are connected just like this. ![]() NOW THE SAMMI page ![]() bingo? RE: problem with TPS sensor - fixkick - 04-23-2020 SMP makes your sensor TH147 Throttle Position Sensor for sure. SMP is huge, a huge world wide seller.(maker) any autostore can order it. https://ecatalog.smpcorp.com/STD/#/vehicles click see? RE: problem with TPS sensor - javi2020 - 04-30-2020 (04-23-2020, 06:49 AM)fixkick Wrote: SMPHey, buddy!! you can see if you can help me, there's some way to be able to regulate the TB screws, one of them carries a spring that regulates relenti, is there? and the other is the one that is in contact with the dashpot, and it seems that it contains some white paint but has no fortuit, I think they have been modified, I appreciate your good help, a greeting RE: problem with TPS sensor - fixkick - 04-30-2020 both are covered in the manual, FSM. (factory service manual, and on my Duty cycle page) the dash pot is set hot engine at 2500 RPM that screw. on the DP is set buy forcing the DP to go active, on hot running engine. the TB base TV screw is for setting ISC duty cycle only ! the ECU is hard coded for hot 800rpm and can not be changed, only the duty cycle can be set to 50% (no idle up commands active, like AC off, head lamps off, and blower off and defrost off) RE: problem with TPS sensor - javi2020 - 05-02-2020 (04-30-2020, 11:13 AM)fixkick Wrote: both are covered in the manual, FSM. (factory service manual, and on my Duty cycle page)I can't find the FSM service manual so I can look at the screws, you can show me where, a friend greeting, thank you RE: problem with TPS sensor - fixkick - 05-02-2020 (05-02-2020, 03:34 AM)javi2020 Wrote:1980/90 G16 right? 1.6liter engine RIGHT>?(04-30-2020, 11:13 AM)fixkick Wrote: both are covered in the manual, FSM. (factory service manual, and on my Duty cycle page)I can't find the FSM service manual so I can look at the screws, you can show me where, a friend greeting, thank you no lie, finding 31 year old manuals are not easy, (ebay has them if you keep and set a watch searched there, waiting...) but this site here new shows it. (not tried by me but here it is) https://www.genuinesuzukimanuals.com/cart.asp?rtn=2|25|3 the web site has 80/90 facts, here are some links to those 2 very unique year cars. spark: https://fixkick.com/no-spark#89 http://www.fixkick.com/IGN_timing/89-timing.html tps calibration is after you do Dutycycle first ( at TV stop screw) (TV = throttle valve) https://fixkick.com/tps-testing#1989-90-only-calib. duty cycle is set with the TV stop screw. ( this can be done with a volt meter on DC volts across the 2 ISC wire pins, set to 7vdc running, (1/2 alternator output is 14/2=7v) this is if you do not own a DUTY cycle meter, this above method. the Duty cycle page is here.(not done like 1991 to 98 at all) UNIQUE ! 91+ manuals are useless HERE. https://fixkick.com/IDLE-AIR/89-90-idle-air.html and last after TPS calibration is Dash pot screw adjustments at the DashPOT screw shaft. TPS calibration. https://fixkick.com/tps-testing#1989-90-only-calib. DP calibration. methods. (always last) Hot engine, 82C. activate the Dash pot with hand vacuum tool vacuum nipple to the tool (the never touch screw TV only applies to 91 and newer G16 TBI engines) on this car there is no idle air bleed screw so must be adjusted (all things relate) form the 1989/90 books not newer cars. oK? https://fixkick.com/IDLE-AIR/Dash-pot.html#calibration ---------------------------------------------------------recap--------------------------------
in 1991 the TBI throttle body changed radically as did the new ECU and matching new electronic advancing distributor, totally unlike any 89/90. the dash pot only seen on 8valve TBI engine is short duration, 15 to 30 seconds cold start fast idle device, a vacuum servo motor it is. and is covered how to set it in all FSM 89 to 95 , 8valve engines (unchanged this one part device. 16valve has no such DP device. nor does the G13 USA 89 carb engine) RE: problem with TPS sensor - fixkick - 05-02-2020 89/90
RE: problem with TPS sensor - fixkick - 05-02-2020 Dash Pot calibration out of the book actual. https://imgur.com/x6gLmZx
RE: problem with TPS sensor - fixkick - 05-02-2020 tips to tune up any G16 this old. 31 years old. manuals are rare. spark plug gap at 0.028" 0.71mm set the Distributor VR sensor gap. seen in link below. hot engine, not cold. set it to the timing advance value seen on the under hood sticker of the car, USA< outside USA , it is about -8Degree's. BTDC. the steps on 89/90 are not like newer 8valve engines at all, use the 89book only. https://fixkick.com/IGN_timing/89-timing.html then set duty cycle per same manual, see my link per above. (ISC calibration this is) and a DC volt meter can work well. 50% = 7vdc at ISC pins and then set the idle switch closure, called TPS calibration, it really is just the idle switch closure setting for sure. and last if ever at all,? adjust the Dashpot. screw, using above photo rules. during all that , no electrical loads as as the FSM book states means. (no huge alternator loads in truth) no A.C. ON. (air conditioning) no head lamps on no heater blower on. no rear defrost glass heaters on. no load we say, just engine running only load. the screw far far low on the TB is the idle stop TV screw for dutycycle setting the screw just behind the dashpot is just for it. |
