Evap canister purge valve - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Evap canister purge valve (/thread-evap-canister-purge-valve) |
Evap canister purge valve - Breeze - 03-18-2018 My 1995 1.6 16 valve Geo Tracker has a ticking noise from the evap canister purge valve when rpms are increased from idle speed. This happens once the engine gets warm and goes into closed loop. I checked the input from the ECU and it is showing that the signal is in fact on/off. Is this normal? If not what would cause this to happen. I have had the Tracker for over 8 years and have just noticed this recently. When does the purge valve actually supposed to be active? Any help would be appreciated. |
