X-90 clutch cable help - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: X-90 clutch cable help (/thread-x-90-clutch-cable-help) |
X-90 clutch cable help - glen - 04-21-2017 Hi, Me again Can anyone help me on how to change the clutch cable on the X-90 ? The trans end is easy enough but gettin under the dash I can just barley see and feel where the cable attaches to the peddle. I've got the speedo pod out and the other plastic but this looks to be a pain. Do I need to take the hole peddle assembly out ? Help!! The new clutch I just put in has no "feel" to it and Theres no adjustment left is the reason I'm trying to change the cable. Will changing the cable cure that ? This is the biggest problem I've had on these little cars. ![]() One more thing, Is there a manual on kickfix? I can't find it. Thanks RE: X-90 clutch cable help - fixkick - 04-21-2017 sure, the cable is first, not one cable lasts the long. it has to have the proper free play or the clutch will never work right. x90s are very rare car, and the books on it 100x that. but not here. the factory book. you never said the year so ill guess 1996 https://suzukipitstopplus.com/Products/10272-1996-sidekick-se416-sidekick-sport-sv418-x-90-sz416-service-manual.aspx ok, bottom off. check, first. the cable goes thought the fire wall and has mount there, unbolt the mount. then the top end of the cable has simple shackle (like horse saddle stirrups) http://www.fixkick.com/tranny/clutch/clutch-on-kick.html see the last photos for cable and clutch,. ill look now it he parts drawings. the push bottom end and wiggle top and the stirrup jump free of the top of pedal HOOK. see part 25 here? do you have a new cable yet, having that first, tells the installer , whats possible and not. inspect of pedal weld breakage, (common as nails with the cables seize as all do) http://www.fixkick.com/tranny/clutch/clutch-on-kick.html take out front seat so you can work 10x more easy yet>? its a shrunken Vitara, and that act only makes service harder. RE: X-90 clutch cable help - fixkick - 04-21-2017 the x90 is same, deal same hook on top. just looked, at the parts drawings. getting it to put back is harder than unhooking it. at engine side, there are 2 screws at the cable mount, off them. then push the cable (other end mounts are off) push cable in say 1 inch or more. that at the above stated mount, wiggle it and it WILL UNHOOK, at hook 26, see photo? its putting the hook to sturrip back that is fun, (hard) really seat removed makes all cars easy to fix under dash, 4 bolts and its out. best way is to USE 2 persons. one at other end (at bottom of car) fully disconnected. there. you at top. then insert the new extended sturrip cable , through the fire wall and get it on the HOOK the other person pulls cable tight. to keep the stirrup from falling off. then get the other end connected and free play set to spec. see? BOOKS, the new book is expensive. its in Paper only... yeah. use ebay feature to have THEM email you ever time words X90 gets, posted, expect long waits. its a very rare car. only seen one ever. read x90 photos. part 26 is the hook. ![]() ebay, search x90 manual then click "follow this search" bingo , get mail now... like this http://www.ebay.com/sch/i.html?_odkw=x90+manual&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xx90+suzuki+manual.TRS0&_nkw=x90+suzuki+manual&_sacat=0 you will see scalpers, this is where they hang out , At fleabay. its a rare car and 10x more rare the books and the scalpers KNOW THAT. RE: X-90 clutch cable help - fixkick - 04-21-2017 the cables inside wear a groove (hidden deep inside) that cause it to jam and stick get rid of the cable now. new one. only. RE: X-90 clutch cable help - glen - 04-22-2017 Thanks guys, I'm workin on it |
