96 Tracker Speedo - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 96 Tracker Speedo (/thread-96-tracker-speedo) |
96 Tracker Speedo - Steelo - 03-02-2017 hello i have a 96 tracker with speedo trouble pretty sure from what i am reading it is the cup, my needle has twisted off . my question is can i take the reed switch and the cable hook up and put in a 96 with auto transmission or is the gearing in the head different and will send funny signal to the ecu?Mine is five speed ,4x4,two door,ac,1.6.L? i bought the auto speedo off of flea bay and the numbers on the back do not match.Got excited when isaw it did not have but 63000.did not see the back of it my bad and the speedo hook up was broke off.
RE: 96 Tracker Speedo - fixkick - 03-05-2017 yes the cup bearing ,wrecks then wrecks the needle bad. not sure your end goal there. 9 some want it all, others only need VSS working, heck with needle, other just want the noise to stop. but yes, you can mix heads , by in 1 Generation , 96 -98 is yours. there are lots of lamps you may need or not need, but what really matters are connector count and there pin counts the end of cable has plastic gears they match axles. sorry you got ripped you cant swap internal head guts (2 to 4doors), ive had to mix up to 3 to get one perfect head. But must have doors correct. on many the missing lamps are there, wired, but need a lamp twist socket only have you seen my head matrix tables? wish you had posted both head bottom tags? but if GM tags, oops. i cant do those. only if head has real suzuki tag. some do. lots of clear choices here http://www.fixkick.com/sensors/speedo/cluster-frack.html 13x10x16 96 rear http://www.fixkick.com/sensors/speedo/slideshow-just-cluster-backs/html/image_13.html http://www.fixkick.com/sensors/speedo/slideshow-just-cluster-backs/html/image_16.html i have exploded parts list drawing on all, i have steps to swap parts i looked now the 2door and 4door meters are different you need a 2door head the correct head is 34100- prefix suffix -68ab0 no ABS -68aa0 ABS RE: 96 Tracker Speedo - Steelo - 03-08-2017 Hello thanks so much for your reply> i have put in a Tom Tom to tell me the mph since my odometer and trip meter is still working. i will check in again with any problems i have in the future. You are the go to person. Thanks Again Steelo |
