Need help on my 97 side kick. - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Need help on my 97 side kick. (/thread-need-help-on-my-97-side-kick) |
Need help on my 97 side kick. - sstaten69 - 08-24-2016 Need help was sitting in the Suzuki listening to the radio and I took the dome light bulb out. When I put it back in it arced and radio went off. When I started the car the check engine light came on. I know have no radio, dome light, running lights, tail lights and the check engine light is on but it wont read any codes. Any idea what I did. I checked and even replaced the fuses and nothing... RE: Need help on my 97 side kick. - fixkick - 08-24-2016 (08-24-2016, 03:32 AM)sstaten69 Wrote: Need help was sitting in the Suzuki listening to the radio and I took the dome light bulb out. do you have the list for fuse locations> 97 sidekick is it a G16 engine or the J18 sport, both are totally different cars. and wiring all diffr, too. RE: Need help on my 97 side kick. - sstaten69 - 08-24-2016 Its a J18 sport. If I shorted out the dome fuse wire know what? RE: Need help on my 97 side kick. - fixkick - 08-24-2016 (08-24-2016, 04:31 AM)sstaten69 Wrote: Its a J18 sport. If I shorted out the dome fuse wire know what? no, shorting the DOme power feed should not damage anything but the fuse. the fuse is just for this event, imagine if no fuses, you get a fire, shorting any power feed. the fuse blows instantly, protecting the car and you, just like fuses in your home do. let me look at the SPort wiring, ,back, in a flash. oops one more question, is car a CANADA car, with DRL (daylight running lamps, ) they run them there, and by law, and are wired totally different than NON DRL cars. RE: Need help on my 97 side kick. - fixkick - 08-24-2016 the usa car has a fuse marked trail, dome , so you can see , if you blow dome, tails are dead (all parking lamps dead) that is a 15amp fuse in the dash box. the IG fuse runs ignition and Radio on this car, (stock, ) so if you blow IG fuse , no engine can run,. on 96-98 sport. i guess the head lamps work and engine runs. so , you did blow fuse. dome/park/tail is cab fuse #11 keep in mind fuses that look good can in fact be bad. use use a voltmeter or ohmmeter to test fuses, live. for volts, or in hand for ohms. (fuses that look bad are always bad) my guess is you dont know where fuse 11 is, nor its location or it looks ok and is not. so l show you the fuse box. next RE: Need help on my 97 side kick. - sstaten69 - 08-24-2016 Fixkick, thanks for the help guess while sitting upside down and checking fuses I missed the dome/tail fuse and bingo that was the one.. Thanks again for the help, time to go and pick up my tools... RE: Need help on my 97 side kick. - fixkick - 08-24-2016 ![]() ![]() replace the fuse, and I bet it all comes back. RE: Need help on my 97 side kick. - fixkick - 08-24-2016 we tied. RE: Need help on my 97 side kick. - fixkick - 08-24-2016 as they say easy peasy Japaneezy |
