Bad ECU 1.6 8v 1990. - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Bad ECU 1.6 8v 1990. (/thread-bad-ecu-1-6-8v-1990) |
RE: Bad ECU 1.6 8v 1990. - Lynyrd - 11-23-2016 thank you very much fixckik! tell me please a corrects pins for "+" and "-" for testing ECU; i will testing this. the cap Hitano(not hitachi) haves a correct polarity,all caps polarity OK. Multimeter test acid traces OK. R102 test OK. RE: Bad ECU 1.6 8v 1990. - Lynyrd - 11-23-2016 if my ECu is dead this have i mount this ECU (the umber is the same but interior not the same)
RE: Bad ECU 1.6 8v 1990. - Lynyrd - 11-23-2016 its ok for testing? PINS A24 B10 ground PINS B1 B7 +12V RE: Bad ECU 1.6 8v 1990. - fixkick - 11-23-2016 if the ecu fails the 4 wire bench test its a bad ECU the bench test. is easy. lacking connectors, ( have the proper jig as you can see in my photos) lacking that. only tiny what are called ball clips work best is from inside ECU, at the 90 degree pins. seen there. the green connector with large pins are the power pins. (and big outputs) I dont have 90s book. so... no drawing of the connectors, for PIN ID (identification) but the schematic is clear, once pins are ID'd, seen hear. do you have an LED, and a , 12vdc power supply ? the below is OUR ecu, there are over 50 ECUs used world wide, so........ mostly SMOG differences but , some are near same, 60a are near. our 60a ecu. B2 and B3 are ground. see that? to the minus power, of battery or a power pack, 12vdc, 2 to 5amps rated. or more. fused to 5amps. max. B1 and B7 is power, 12vdc. + B13 (CEL) to a LED (minus cathod side here LED then Plus LED pin anode and then a series resistor to 12vdc + supply (500ohm resistor) B13 to a lamp rated at 0.1amps or less. never more !@!!! to 12vdc + pin. turn on power, CEL glows. ground pin A15 (diag pin) CEL must flash or the ecu is BAD. end test.
RE: Bad ECU 1.6 8v 1990. - fixkick - 11-23-2016 (11-23-2016, 01:27 AM)Lynyrd Wrote: if my ECu is dead.the outside numbers matter, not the secret inside number. the outside matters is your car 2doors. , or 4 2wd or 4 what transmission,?? all these facts matter, for ECU, (and year) first off, tell what car you have. like this 1990 Vitara, 2door, 4wd, 5speed, with 60Axx ecu.?????????? then tell what other ECU you have, out side not inside, the outside sticker tells you what it is, (suzuiki numbers only) 60axx the xx changes, by many important things. or report exactly what car it came out of, for sure the transmission.
RE: Bad ECU 1.6 8v 1990. - fixkick - 11-23-2016 ok lets start over My vin number is JSAETA01V00108621,Suzuki made in Japan. Code 25 for Holland. ECU number 33920-60A70 (real suzuki numers) E2T40671 (secret Mitsubish codes) 9316B (my guess, this is version numbers all a secret from Mistsubishi, under contract (secret) via Suzuki. market 25 is clear but what car is this ,you never said what car you driveing 90 G16a SE416 Vitara, doors? 2 or 4, ,2wd or 4wd, what transmission the 5 speed? manual stick? (0r automatic 3 or 4 speed) you never photoed your body tag the tag tell everyone what the car came with new. that FAE number tell me that. see this, see those suzuki codes, ? the ecu must match this too,. I have the book on this too. ecu numbers all.(outside numbers never inside ECU) http://www.fixkick.com/specs/Body-TAGS/bodytag.html then tell outer sticker on spare ECU and better what car did it come from this spare ECU, tell full spec, on car, this matters the most. it must be a 60axx ecu, no others work on your car. the xx means what smog car uses, and what transmission and weight class. and if 2wd or 4wd. (matters) RE: Bad ECU 1.6 8v 1990. - Lynyrd - 11-23-2016 this is vitara 1990 g16a 8v 2 doors 4wd 5 speed manual transmission; ![]()
RE: Bad ECU 1.6 8v 1990. - fixkick - 11-23-2016 using European vin decoder found out its 2doors, (called 3 doors in Europe) your Vin shows, car is metal body, not canvas top convertible. and is 5speed stick shift (good, as both ecu work on stick) tag code, FAE or FAK body, then code 62, but is car 4wd or not? ECU:for this type 1 , calls Europe car. the 60a70 is, mt , and is E22 German smog rated the 60a80 a/t auto. (may work in m/t ok0 the 60a32, is m/t and is for markets e18/39) Switzerland / Austria ) my guess is all 3 can work in your 5speed car, and the parts list for this year, does not mention 2wd/4wd differences. 4wd matters on many cars, due to , its shuts down (or changes), ABS , or cruise, or shuts off , A/T trans clutch lockup or shots off overdrive. none do you have. RE: Bad ECU 1.6 8v 1990. - fixkick - 11-23-2016 wow my first holland tag ever and is LAK625k25 that LAK tells what car you have. thje 5k means JLX grade car. RE: Bad ECU 1.6 8v 1990. - fixkick - 11-23-2016 so what is this spare ECU what car donor did it come from and the outside tag. show the 60axx numbers, |
