Catconverter burn-up.. - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Catconverter burn-up.. (/thread-catconverter-burn-up) Pages:
RE: Catconverter burn-up.. - fixkick - 11-20-2019 part 1 is 92-93 fed car only e3 (not calif E33) cars. but parts do get mixed up. for sure on old cars and engine swaps, and us, wrecking yard scroungers. The cal cars and 96 all have long exhaust manifolds (stock) see my chart here on the many manifolds used. by year. best is the cat mounted close to here as possible, and pellet cat better. (I bought this new, 2007) for sure , other aftermarket manifolds can work too. (with EGR port) One other trick (like race cars do but not for CAT) for custom manifolds is that high temp exhaust pipe wrap tape, that will send more heat to the CAT.
RE: Catconverter burn-up.. - TomPrestin - 11-20-2019 Quick response before I have to step into work- did a lot of reading through the the site yesterday, noticed that standard plenum vacuum at hot idle should be 20 inHg, mine is stable at 8.. so I may have a vac leak somewhere, probably contributing. I have a new VSV2, and nothing under the hood is "custom" I've gone to great lengths to make all the mechanical components as original as possible. Header was cracked bad, currently running a dougthorley, no funky tube, goes directly to Cat inlet. Cat hangs from rubber grommets so I'm sure it is bouncing around a bit, also maybe contributing. my scanner will log/save so I'll pull down the info and post. thank you!! I'll update again asap RE: Catconverter burn-up.. - fixkick - 11-20-2019 (11-20-2019, 02:13 AM)TomPrestin Wrote: Quick response before I have to step into work- did a lot of reading through the the site yesterday, noticed that standard plenum vacuum at hot idle should be 20 inHg, mine is stable at 8.. so I may have a vac leak somewhere, probably contributing. I have a new VSV2, and nothing under the hood is "custom" I've gone to great lengths to make all the mechanical components as original as possible. Header was cracked bad, currently running a doug thorley, no funky tube, goes directly to Cat inlet. Cat hangs from rubber grommets so I'm sure it is bouncing around a bit, also maybe contributing. my scanner will log/save so I'll pull down the info and post. thank you!! I'll update again asap 19 OR 20" IS HOT IDLE, 800RPM AND NOTHING ELSE , not cold , not 8. SO RPM IS important here. the engine cam must timed correctly and compression near 180 PSI, all 4, then no melted cats, if melted the engine can not pump air, and can not have normal vacuum. the header can not be cracked or it sucks in air, and makes the 02 front go NUTS. the Exhaust pressure pulse, goes Positive then goes to slight vacuum each PUTT . (AND CRACKS ARE NO GOOD HERE, NO CAR WITH EFI GOOD with cracks near O2) was cracked, or is?. so the Thorney has no EGR #4 port? You say?, if yes, no port EGR will never work, ever. ((ahh funky means 90deg suzuki front tube, sure) you should do photos of what you have so wild questions end , old cars, have wrong parts and bad parts and missing parts, endless , but yours is not. got it. 8" inches HG vacuum is NO GOOD ever, (unless EGR sticks open or what told above) vacuum wrong is big time serious. on an normal engine, we see about 19" hot 800 idle then blip the throttle and vacuum drops fast and recovers fast when released. with a melted cat if car runs at all, some do not ( the vacuum acts very odd and very slow to recover, unlike any good engine behaves. is the cat sized for 1.6L or 3L/? sizes matters, to get it lit off and keeping that way, only correct sized cats work. ECT read 300 ohms hot engine, if not burn up cat you will, (ECU sees below 150f water temp for actual hot engine goes rich and is very bad. 180F is correct or more, 195f are sold. some folks in EU have like 3 types of ECT and buy the wrong own, and pure hell ensues. when p0400 pops we scan and get the freeze frame so we can see if EGR A or B test failed. one is cruise and other us cut fuel test. ( we see this with vacuum readings in the freeze frame) but with 8HG vacuum the tests have no change for sure the cut fuel mode, EGR B test. hopeless.... cam timed right. (not using the 16v cam cog wheel false marks !!!) spark timed right compression at spec, 180psi at sea level, my compression page covers correction rules for folks at height altitude. the vacuum at 19" HG hot. engine 800 rpm. those are the basics on the engine, if not right, EFI can and will go nuts, the EFI adjusts for normal engine wear and 8" Vacuum is not normal at all, not even 1/2. RE: Catconverter burn-up.. - TomPrestin - 11-20-2019 todays information- then questions. fyi I'm getting paranoid that I'm destroying an engine I spent the last 2 years hunting down parts for. old header was cracked, thrown out. new thorley header does have EGR port. looked extensively tonight at all vac hoses/connections, and header, all are connected correctly and don't see any leak points. Scanner does freeze-frame when coded- freeze frame from today says: DTC Code: P0400 Fuel System1 status: CL Fuel System2 status: ... (not sure if this is applicable or not, but its listed in the frame) Calculated LOAD Value: 19.6% Engine Coolant Temp: 177f Short Term Fuel Trim - Bank1: -1.6% Long Term Fuel Trim - Bank1: 1.6% Intake Manifold Absolute Pressure: 8.7 inHg Engine RPM: 2547 Vehicle Speed: 49mph Doesn't say anything about EGR A or B. seems like something is missing.. you and me both. I took multiple other snapshots tonight while driving and then arrived home basic info listed here. not sure if it will offer any insight but I'm at a loss on it. especially the low vac pressure: DRIVING SnapShot1: Long Term Fuel Trim - Bank1: 0.8% Intake Manifold Absolute Pressure: 15.6 inHg Engine RPM: 3030 Vehicle Speed: 75mph Ignition Timing Advance @Cylinder #1: 33.5degrees Snapshot2: Long Term Fuel Trim - Bank1: 1.6% Intake Manifold Absolute Pressure: 12.9 inHg Engine RPM: 2585 Vehicle Speed: 66mph Ignition Timing Advance @Cylinder #1: 30.5degrees Home, Idle hot1 (no accessories on): Long Term Fuel Trim - Bank1: 2.3% Intake Manifold Absolute Pressure: 8.1 inHg Engine RPM: 787 Vehicle Speed: 0mph Ignition Timing Advance @Cylinder #1: 10.0degrees Home, Idle hot2 (no accessories on): Long Term Fuel Trim - Bank1: 3.1% Intake Manifold Absolute Pressure: 8.1 inHg Engine RPM: 803 Vehicle Speed: 0mph Ignition Timing Advance @Cylinder #1: 9.0degrees To add to the confusion cold idle is now very high. Upon beginning of cold temps here it would run 1500(ish)rpm when cold, then settle right down when warm. Now running 2500-3000 cold, settles down as normal when warm. Simply a change I thought might add insight to this conundrum. Still doing newly revealed mild hiccup also, mostly at cold idle and also at barely open throttle- cruising. I'll send pictures of engine bay tomorrow when sun is up. My paranoia and lack of experience leaves me with these questions (in response to your check list) tonight: 1. Is is even possible for the engine to run as well as mind is with incorrectly timed cam? Been my daily driver since I got it all put back together in April. My assumption (very possibly wrong) is incorrectly timed cam would result in pretty dramatic loss of power and awful gas milage? 2. Upon more reading on the site today, says cam is timed at #4, but then in instructions for setting timing say to connect timing strobe to #1 SparkHV lead. Is that correct? I followed those instructions at original reassembly, so not questioning, just confirming to eliminate variables for my own piece of mind. 3. I'm just plain baffled. Trying to keep an eye on O2 graph readings while driving, both seem to be swinging as if working correctly, but I am sure no expert. Only time no swing is closed throttle while moving (hard deceleration) all O2 values drop to bottom until throttle is reopened. I'll download that info and post as soon as possible also. 4. Paranoia says I timed something wildly incorrectly, but its hard to believe that's the case as its capable of running stably, consistently, been my daily driver since the early spring, with no obvious signs of problems other than this CAT burnup ordeal. Thank you for all of your input, knowledge and suggestions. RE: Catconverter burn-up.. - fixkick - 11-20-2019 (11-20-2019, 06:17 PM)TomPrestin Wrote: todays information- then questions. fyi I'm getting paranoid that I'm destroying an engine I spent the last 2 years hunting down parts for. Let me explain limphome and only for EGR. some of these cars (and by law) if the EGR fails, that means the car is NOX polluter, for sure. (driven hard) the ECU seeing EGR 400 fail, may in fact go rich NOW, and this can and will overheat some CATS. (depends on maker of cat and mode) if you have NOX, the best solution of all to ending NOX is to go rich, Rich cools combustion and NOX ends NOW. this is in fact mandated on some cars then and now. dealing with NOX is serious (acid rain and burned lungs ,etc) so the car may run perfectly until 400 sets, and then goes rich, not saying yours does, but many cars do. It may also flash the CEL lamp (missing on your car) and the flashing CEL means CAT burn up , is soon, the operators guide tells you to not pull a trailer and drive slow and fix car. I'd say all is good, but EGR failing and CATs melting, only why remains. The cat some sold new are what I call weak cats, unlike the 1996 robust cat, the new cats do not last long of fuel mix goes out of control and for long time (weeks) By the way thanks for sharing your data. (data is king) The EGR test #1 is first. at the MAIN< and is behind the exhaust manifold #4 runner rear, and very hard to see much less touch. so we use hand vacuum tool like the video shows. and see RPM fall from hot 800 to 400 or stalls, end test. we do that first. then check the bark tube for barking pulled, I call that the bark test, (putt putt putt) keyoff, tube pulled (below MOD) and start engine hear the tube port bark. loud. if not there are 4 places this blocks, EGR main (bark port)packed in carbon, intake mAN- S bend packed, head tunnel packed and the Thorney tube packed in carbon. if bark passes. last is the live test all this in covered on my EGR page, step by step next is LIVE test but your car has no real speedo, VSS must work or the EGR will be dead,, on all these cars. (1993 and newer, approx but 1996 up for SURE) the EGR will never open at 0MPH ever,by hard coded ECU internal firmware logic. also clean the MDP, just get its port on the bottom clean, no gunk there, so it can work right, (note I assumed it is 1996 old , here) the plenum on theses cars are a mess, (the EGR cloud hits the PCV valve, could and forms GUNK, this gun lands all to easy on the MDP port) making read wrong or go slow. The ECU is lame, the OBD2 should check the MDP 3times, by it self but does not, keyon, idle and cruise test. but no it does not it just does the 2 EGR tests. and one fails. Im not sure (im not firmware genius) but if EGR test A fails, test B may be aborted, A = Cruise test, B= moving fast cut fuel tests.(throttle at 0) test A proves EGR main opens, test B proves EGR main closes. it does differential MPD readings to do that, (it does test A valve closed then opens it and gets 2 readings from MPD, and the difference in MPD pressure, is checked, (pass/fail) MDP page. the GM EGR truth page, A and B. (hard to find but I have it) PAGE1 and PAGE2 cheers and good day. RE: Catconverter burn-up.. - fixkick - 11-20-2019 if the live test fails then we test the vacuum devices, many. the live test, kicks off with. hot engine, idle normal to start. 1mph or faster (rear tires off ground VSS clicking away. factor stock Care, VSS in speedo head stock) transmissions are in GEAR, to spin rear drive shaft. then VSV1 opens, and then you open the throttle and vacuum hits the VSV1 and VSV opens now and vacuum hits the MOD port. if cat back pressure is not 0 or not 10psi,(melted) the MOD sends the correct vacuum to the EGR main and it opens and flows exh gasses to the intake EGR mono port. as you increase RPM (and mph) the flow increases in direct proportions to cat back pressure, this is how EGR works LIVE in the old days 1993? or 92, no need to spin real wheels at all. and EGR opens even parked in neutral. seeing it open may take a MIRROR on any 16v. As you can see most of this takes 2 men ( or Gal) one to drive jacked up in the air,and one to use a mirror to watch the DIAPHRAGM move inward. Not a very safe test, but taking off rear tires would make this saver. the rear axle turns and the speedo cable spins and the speed clicks VSS and EGR opens. the rear axle drive prop shaft must turn even gently so.... be safe ok? RE: Catconverter burn-up.. - fixkick - 11-21-2019 one more just a photos to show all places vacuum air leaks can happen and do. All engines want to leak , a vacuum loves to fail , even sucking in gaskets and more. I added what I think (crib note comments) all possible failure paths. on normal engine cold air supply is only IAC. (and the bleed ,tiny air) my first 96, had broken mount, at Red #3 and suck air like mad and crazy symptoms,
RE: Catconverter burn-up.. - fixkick - 11-21-2019 i have used clay to block the IAC input port, put back the air horn so MAF is working then start the engine, it may take right foot action to keep cold engine running with Dead IAC> but what the engine does now tells you if the IAC is bad, or there is this other leak. of air. The IAC closes 100% hot, and must, if someone tuned duty cycle to 50% with the bleed screw and there are leaks, then when the engine is cold the air leaks add to the IAC normal flow. my point here is sometimes, folks adjust the bleed and used that to hide air leaks, hot. by screwing the bleed screw in 100% CW clock wise turned. see? Duty cycle is set on hot engine only, using bleed so the ISC is in the middle of its dynamic rage, and done only if no illegal air leaks are present. if the bleed is bottomed out, that is a RED FLAG. RE: Catconverter burn-up.. - TomPrestin - 11-21-2019 [attachment=886 Wrote:fixkick pid='12318' dateline='1574168998']CAT 101 : basics (then covering beat to death CAT last) Took pictures under the hood today- will post tomorrow after converting. Did EGR test, seems good, does as your test suggest when opened, recovers quickly when released (closed). Considering how many times I've had this thing in pieces I am certain there is/never was (possibly removed by PO) the #17 body to frame rail mount for CAT, so something to look in to. I actually have a boost/vac gauge of the same set as currently installed, but not hooked up yet. I'll try to get that accomplished this weekend also and have constant eyes on actual VAC levels now that you've informed me scanner is not accurate direct vac reading. (thank you) Both 02 sensors seem to be doing what they should as I observe during regular driving, will still pull down info and post when I have time. forgive my ignorance, but I'm lost on the CAT "LIT" subject. mostly because I don't know definition of LIT. Searched site and couldn't find it in the jargon area. On the high idle- Apologies for the location confusion, I'm in Minnesota. vehicle was originally a Florida car (where I found it) but now resides in MN, so winters are cold. first cold was 10-20 overnight, a few weeks ago. Started as expected ran 1600rpm until warm then dropped to 800. recently warmer (last week and this in the 40's) but idle surging on start up to 2800rpm, holding there until warmup then dropping down to 800. possible IAC or ISC just need cleaning? or indicator of vacuum issues waiting to be tested/visualized. Again- I don't see any places with cracks or damage that could be causing the vac leak, but certainly not going to stop looking. On the subject of headers- as stated I have the Thorley, which you are correct the EGR port is not well designed. Alternately the gasket they send for mounting is a softer compression gasket which I have to imagine could EASILY press into the machined EGR passage and block it partially or completely simply with installation. IF I'm following correctly- EGR test good suggests all EGR passageways operating reasonably? For sake of convo; if the EGR exhaust port were blocked, could it be a contributor to the CAT burnup issue? More to come when I can make time! Thank you!! Pictures finally |
