in 1996 the crank sensor was added to the bottom of the pump housing, by EPA mandate (OBD2 tech)
I just revised this drawing with ISC > IAC links.
the cars underhood sticker shows vacuum but that sticker nor mine below shows the 3sp A/T vacuum to the 3speed vacuum modulator. that fitting is located on the rear of the intake manifold. seen here in this slide show.
