My Speedo Cluster Collection.
I had to buy many broken Clusters to make one good head, with a good
Tacho.
Key points on buying a used head, Year range,
TACHO,
Connector position on rear, Pin count on rear, AT/MT, 4WD.
The most common cause of VSS (veh. speed sensor) failure is
corroded
Flex PC pads, so erase them as
the photo shows. Next if the Speedometer mechanism is bad, the VSS will
not work, because there are up to
3 worm gears in side the speedo that make the VSS click. The
actual VSS clicker is just a cheap reed switch.
Best place to get a used head is on Fleebay and and Car-parts.com.
Never buy a head unless you have a photo of the rear ! , and the P/N on
the bottom edge. 34100-xxxxx.
Hope this helps someone.
