Threads: 4
i can't say it doesn't work but it is very weak . I took the drum off to observe its operation , there is about a 1mm difference in diameter across the shoes handbrake on/off. The lever 25-26 seems to have no means of leverage except a little at the top against adjuster 21-22 . assembly seems correct as it looks like no room for error . Brake lever set for 7-8 clicks
95 sidekick 8v 2dr cdn , new drums / shoes
any ideas ??? thanks ,
Threads: 4
update; i fixed it but i have no idea how. ordered 2 new cables L & R , changed out the L one and that seemed to fix it but it changed nothing that i could see as the old cable was intact and the same length as the new one . One problem [ ?? ] remained as the R cable seemed longer as the yoke [ at the lever ] did not sit square. So i replaced the R cable which did not change anything . Examining the old cables i found that the R cable was indeed longer than the left , i have no idea why as the vehicles layout looks symmetrical. Two L cables would work better in my opinion. [[ & Adjusters were actually working [[
