Hi,
I have a 1991 Suzuki Vitara JLX 4dr (Auto Transmission) G16B 16v EFI, and the Tachometer does not work, the car seems to run fine but the needle just stays at its lowest position. I have checked all the connectors around the Dizzy, Ignition Coil & Noise Suppressor & the connections seem to be good... I also removed the Instrument Cluster & checked all the connectors on the back of it.
Any idea's what the problem might be ?
Cheers...
Cheers...
