TV (kickdown) Cable
I am having problems finding a TV (kickdown) cable for a 1993 Geo Tracker 4wd Automatic and ideas where I might find one. There is one on EBAY but no returns if it's not the correct cable I'm out the money and not sure if it's made overseas. Thanks
3SPEED 8V
It is a 1993 Geo Tracker LSI convertible 4WD 3 speed automatic 8v 2 door.  Thanks
i will now show all numbers for Kickdown cable TV,  1993.
by suzuki, for USA not canada.
4speed,  24751-57b00 ( 00 can be higher for newer versions.
3speed, 15940-61a00 (ERROR CORRETED)
both suzuki warehouse show no such parts now.  the end.
leaving , used parts,  NOS parts and aftermarket
the 4 speed is hard nut , to swap,  dropping the pan and valve body to  get to cam wheel, TV
the 3speed fits here, at the rear. at valve ID 20,  , this the GM box TH180 based, same 1974 to 2013 made.  3L30 box (4wd possible)  super easy this,
[Image: auto-base1.jpg]
4speed the Kickdown cable is just behind that shifter PRNDL wire bundle here, and is very very different and way hard to replace, hard nut hard.
[Image: zuk-slush-pump4wd.jpg]
to get the right cable take known 2 things, what transmission you have and what throttle body is there, 8v /16v
some cars made(not yours) but vitara's were made with all 4 permutations,.(world wide variants are large)
in uSA the 4door is 4speed, due to body weight the extra 15hp and the extra load any 4door can load up.
the 4speed has to have the pan dropped to get the cable off the internal cam. there.
i will quote my kickdown page.
There 3 brands, now, Dorman, ATP and Pioneer, all three have online E-catalogs and all show nothing or way less than what is sold in stores.
Amazon has them, so does Oriellys. (Napa told me none, 2013)
ATP makes Y-1174 cable.
Dorman 04445
A Pioneer CA1967 (O’riellys has this and 1 other)
Google Dorman Ecatalog, and ATP ecatalog (it’s a google first hit) and a bad dream.
2012 cables made by ATP. (4 hits of many via GOOGLE) by P/N
This 3sp cable is sold at Rockauto.com
ATP-Y-1174-Detent-Cable on Amazon.
ALL THOSE SEEN ABOVE, ARE 3SPEED BY MY EYEBALLS 89-95 8V.
lets now see of dorman still makes this cable.
oops dorman ended there cable sales for this.
ATP ecat
bingo just the 3speed 89-95 is the 1 clue means 3speed, 89 had no 4speeds then.
https://www.showmetheparts.com/ATP/
Pioneer CA-1967 (details weak)
https://showmetheparts.com/pioneer/
rock auto, calls them detent cables.
https://www.rockauto.com/en/catalog/suzu...cable,8484
the 3speed AT kickdown cable suz # 15940-61a00 89-95 8valve only 8v throttle body, 3L30 box, 3speed)
the 4speed, is 16v in usa. and is 23751-57B00 3L-72E
ROCK AUTO AND MOST OTHERS STORE FAIL TO ASK FOR 8V OR 16V AND ARE NOT THE SAME NOR IS 3SP AND 4SPEED
ROCK DOES NOT LIST A 4SPEED BOX, KICKDOWN CABLE AT ALL
I SEE NO 4SPEED SALES AT ALL.
SUZUKI CARS CANADA SELLS IT BUT IS CLONE
https://www.thewrenchmonkey.ca/auto-part...ent-cable/
atp CLONE BUT SEEMS OK>?
IT DOUBLE IN PRICE IN 10YEARS. WAS $30 BUCKS usd
ATP, GOOGLE THIS
ATP Y1174
https://duckduckgo.com/?q=ATP+Y1174&atb=v1-1&ia=web
$41 AT SUMMITRACING.
AND AMAZON
SUZUKI SHOWS NO CHANGE IN P/N AT ALL FOR 7 YEARS 3SPEED SALES IN USA. 89-95.
some seen ball or square end differances, but gee that is OEM clone changes I guess, IDK really, and dorman ended sales.
