08-16-2014, 12:22 AM
(This post was last modified: 08-16-2014, 12:29 AM by cosmic_splatter.)
Fixkick,
When I took the old timing belt off, the marks were perfectly aligned. When I put the new timing belt on and spun it two turns clockwise, the marks are no longer perfect.
What's going on here? I can't believe anything moved between removing the old belt and putting on the new one. As you can see from the photo, it's a few degrees off now.
![[Image: timingjob_zps4256baa5.png]](http://i957.photobucket.com/albums/ae59/johnhovan/timingjob_zps4256baa5.png)
I thought this was going to be easy!
ps. Right side of the belt is tight.
![[Image: Cog%20&%20Ring%20IMG_1169.jpg]](http://www.fixkick.com/t-belt/snouts/images/Cog%20&%20Ring%20IMG_1169.jpg)
![[Image: 96perfect2w.jpg]](http://www.fixkick.com/t-belt/snouts/images/96perfect2w.jpg)
