Threads: 4
So the stock Suspension is stiff as hell and hunting roads sucks. Particularly for my rig as I have removed as much weight as possible for the snow tracks.
So I am going to update the suspension and install a kit to put Camso tracks on the machine for the winter. I am using the sidekick to replace an argo. The argo was just toooooo bumpy as it had NO suspension at all.
I am going to try and update this thread with progress on installing the following"
ATVTracks.net install kit for Camso tracks on tracker.
Airbagit kit to replace coils with airbag suspension springs with compressor and pump and controls at dash. This should allow for adjustable ride height and spring rate for different loads and road conditions.
New front radiator. the radiator in the rig had an aftermarket electric fan that was held in with plastic through radiator mounts. After this weeks hunt they rubbed a small hole in the radiator. will replace with brackets for the fan. Worried that without a shroud the fan will not cool enough but there is no shroud anywhere for an electric fan for this rig and the engine fan and shroud are long gone.
Other things that I will end up having to do to make the above work. may need to replace front strut or a arms to provide more travel for front suspension as the bags technically could travel more than the stock springs if I want them to.
Let the games begin.
Threads: 4
So its no turning back now. I have ordered the parts and they were not the cheapest.
Parts list as reference:
Adjustable Camber Bolts for front strut to allow for camber adjustment after lifting.15 bucks on ebay.
Monroe 32268 Rear longer shocks. 30 bucks each ebay.
Monroe 71831 longer front struts. 30 bucks each on ebay.
Used Auto locking hubs (i had warn manual on it and want to go to the auto because I am lazy) 80 dollars on ebay.
Alteredego 2 inch rear diff spacer. 25 CAD plus shipping.
Airbagit kit for all springs. Includes one compressor. 2.5 gallon tank 4 valves and dash gauges, lines and fittings. the springs are the Denomentor II air spring. Goes from 2.8 inches to 12 inches. Brackets will go into the current spring cups and I will need to cut them down to the lower and upper heights I want. The goal they say is to put the spring at 65% of full at the ride height you want. So that would be about 7 inches inflated at a 2 inch lift from stock. This would it seems allow for the full travel of the new shocks/struts adding about 3 inches of wheel travel above stock and I could ride lower or higher than the 7 inches depending on pressure in the bags. Lower than stock should be a cushy ride higher stiffer. I could go with a 3 inch lift by adding a small spacer on the longer shocks struts..... I am thinking though the 2/2.5 inches is safest and I don't really need much more height plus I can run pumped up to get a little height if I had to anyway. This was 1100 dollars..... Ouch.
A little worried the bags will have clearance issues I will need to remedy but hoping they pop in and no touching. THe welding will be a trick.
I have purchased used UTV Camso Tracks (3k but hardly used) from a maverick and got the install kit for the anti rotation brackets from ATVTRACKS.net. ( glad this is around as building this from scratch would have been a pain about 500 dollars for the kit) Plus 4 inch spacers for the hubs in the front (250 from custom builder) and 2 inch in the back (180) I have to weld a anti rotation bracket to the frame for that kit also. The welding will be tough as I don't have 240 in the garage so a torch??? Borrow a generator?? I don't know I will have to get that figured out later.
More to come.
Threads: 4
Well I have the system installed. I will take a lot of pictures and post an update in the coming days. It was a beast of an install. I would not recommend this install to anyone to be truthful but if you want to be able to lower and raise your ride height on the fly it does work. It also is softer than the stock setup the only issue is its hard to get stock shocks that are soft enough to make the ride work right. I am still looking at how to soften up the struts..... They only make the one version that I have that is the stock setting. when you have the car lighted up as much as possible for snow tracks it is too stiff.
If anyone has any ideas on how to soften up the shocks let me know. I am not above opening them up and drilling out the holes or anything I can do.
thanks.
Threads: 4
Well I purchase the rear shocks for a Chevy Cavalier. Hope they do better than the ones I have now that will work for a HD truck.
Threads: 4
Threads: 4
Well looks like I put too much lift on the rear. The drive-line vibrates at 70 MPH on the freeway and surely will burn up the U joints faster. I can air down the bags and the vibration essentially goes away. I may need to cut the 4 " tube lowering the bags down an inch or so. I hope not as that will be a pain. I also have a a shorter third link spacer for the rear axle that is shorter than the one that was on the rig when I purchased it. Its about a 4" now and the one i got is 2" so I suppose I could give that a whirl and see it it makes a difference.
Onward to dial this in.
Threads: 4
Ok got it dialed in. Swapped the longer rear shocks I had that were too stiff with some 1989 cavalier shocks and it made a huge difference. Cut the cups on the back off and removed the rubber spacer at the top to lower the ride 3" and the driveline is now working properly.
Threads: 4
Threads: 4
