Sources for Rebuilt Cylinder Heads G16B
I think that I am getting somewhere:
From: http://www.zukikrawlers.com/showthread.php?t=55121
I'm not so sure the indexing is critical. with the 13 teeth I think are on both drive and driven gear, the worst you could possibly
be off by is half a tooth or 1/26th of a circle or 13.8 degrees. Looks like there is enough room for adjustment to compensate and
put you back near the middle, or I have forgotten all about geometry.
ON 2ND THOUGHT, IDK
Any updates?
I thought I explained it. Indexing is not super critical. The distributor gear on the camshaft is press on. You can use the heads with the
reluctor if you switch it for the cam driven distributor gear.
