Rebuilt 5-speed making noise
the cluster gear turns slow. as does its 5th and reverse gear extention to same.
so is not that whine, IMO
if is in the box, the front and rear main bearings of the counter shift are bad, or the front gear set,teeth.
drop all belts on the engine for 1min timed, (water dead so do that cold engine only) still whine
the starter pinion jammed OUT (stuck) will scream load spinning that overrunning clutch backwards and is released that ST shaft clutch in that mode, (replace it if suspected fro $10
that tiny clutch keeps starter from exploding.
that is all I can think of that can do such super high frequency whine, not bad throw out as you told. and that only spins 800 RPM hot engine,.
