04-24-2020, 04:55 AM
Car sometimes won’t crank, usually I’ve fixed this by putting it in neutral and slamming on the brakes, must make things connect right.
Thanks to your crank diagnostics I can only assume it is the PRINDL position sensor as I was able to start it by moving the gear selector back and forth instead of shaking the whole car.
I’m having difficulty locating the part on eBay.
