12-03-2019, 12:57 PM
Hi, can somebody help identify the power door actuators of the 5 doors of Suzuki Sidekick Sport 1.8l engine??
Pics would be best and where they are located??
Power door actuators!
the 1.6door are same place, and same way to access them , 1.8L books are rare (as is car)
from post#1 sticky , the 96 free manual is still there. look and read this, the 1.8L book (supplements) flat say to read this exact book first, https://www.acksfaq.com/HTML/trackerfsm.htm see that>? removing door cards is the topic, your mechanic can show you in 5 minutes work.. answer they are inside the door, all are. locks and lock actuators, if you learn to use youtube, all this is shown, vast times the subject is how to remove door cards. (endless examples,) [url=https://www.youtube.com/results?search_query=how+to+remove+door+cards][/url] book v1, 10.6 (chapter BODY and DOORS) https://www.acksfaq.com/HTML/pdfs/96-FSM-v1-10-6.pdf book v1, 8a-130 cover power locks https://www.acksfaq.com/HTML/pdfs/96-FSM-v2-8a-130.pdf on the main page above search word power. see power windows. and powered mirrors. its all there, just read it first the ask questions. if you try to remove any door card, all things on to front of card are removed firsts or it will not come off. ok? there is your starting point fact. the door cards use POP, out rivets, that you pry with plastic pry bar. ![]()
12-04-2019, 12:17 PM
(12-03-2019, 11:24 PM)fixkick Wrote: the 1.6door are same place, and same way to access them , 1.8L books are rare (as is car) Thanks. The door behind the driver, that does not have door lock, just stops working, cannot lock and unlock. Does each door must have one separately?? |
« Next Oldest | Next Newest »
