07-28-2016, 02:22 AM
(This post was last modified: 07-28-2016, 03:31 AM by Helluvarush.)
Ok,this is my first post,I've searched everywhere and can't find a clear answer about this. I have a 96 1.6L 16 valve engine, one of the rocker arm adjustment lock nuts came loose and bounced around the valve train,needless to say it's MANGLED. I've looked everywhere,even went to the junkyard and can't find a nut that will work,anyone know what size it is? M6x .75? I've only found one place that says they can get that size but they want me to buy 1000 of them. SURELY another vehicle uses that size nut in the valve train,however all I could find In the junkyard was dohc engines with roller rockers. If anyone has ideas,or knows where to buy,lemme know
Thanks
-edit-
Ok,I'm pretty sure they are m6x .75 pitch, found a place that will sell them in small quantity,so if anyone else runs into this problem, Fastenall has them
Thanks
-edit-
