01-24-2018, 09:43 AM
all of those are easy to find.
DLC, did you know folks plug in 100s of accessories here now, teen nanny (insurance company) and remote OBD2 displays, and tachmeters ,etc?>
if it is empty that socket then there is no drain possible,.
The radio is there, remove it or gain access to it and unplug it, no need to guess where any radio is.sorry.
the PCm (ECU is behind the left speaker in all 89-98 trackers and sidekicks and vitara (say in EU)
i guess you dont have ABS so, no need to find it. it be super obvious, with lines leaving it to all wheels, calipers and cylinders.
the relays are moved to the right side of the heater box. pull them to see if, drain ends?
my links. 96 to98 dash devices, clearly stated.
http://www.fixkick.com/power-elect/Relays/98-lays.JPG
real photos by me.
see topic every inch of 1996 harness, 98 has no TCM, THEY MOVED IT INSIDE THE ECU IN 1997 AND NOW CALLED PCM.
http://www.fixkick.com/power-elect/Relays/relays.html
GLOVE BOX DROPPED ,my 96, may parts moved in 1996, relays tops that list.
http://www.fixkick.com/ECU/1996/96-relaybank1.JPG
id have the radio out so fast.
they do fail. this way
and unlike Ecu FOR $400 WAY EASIER TO REPLACE, AND CHEAPER AND IS OPTIONAL, NO RADIO NEEDED TO MAKE SPARK OR INJECT FUEL
RADIO OUT IS FIRST.
THE 98 HAS NO TCM.
EVER
SORRY THEY MOVED IT TO (INSIDE THE ecu BRAin)
i will try to read your link here, in the gulf near , Grand Cayman islands.
real photos by me.
RADIO OUT IS FIRST.
THE 98 HAS NO TCM.
EVER
