03-27-2014, 03:39 PM
I'm looking for a leak in a sidekick I just bought (94 5pd 8v 2wd) and I'm working my way through things (easy to hard starting with VC and distributor O rings) and now I removed the flywheel dust cover to see if it was the rear main seal.
I read one of your posts on the Suzuki-forums that the rear main seal leak would make the flywheel soaked in oil. My flywheel is dry but behind it the bottom inside of the housing, behind the flywheel is caked in oil.
did I just misunderstand what you meant, or is this really an indication that it is not the rear main seal?
I've learned a lot from your posts and your site. Thanks.
![[Image: engine-rear1.jpg]](http://www.fixkick.com/tranny/clutch/engine-rear1.jpg)
