OBD2 Engine Start Simulator
the ELM data sheet teaches hot to use AT commands and now to pass OBD2 commands directly to your cars ECU.
in fact
page 32 teaches how to do RPM
https://www.elmelectronics.com/wp-conten..._Sheet.pdf
read page 33 carefully, how it hides the protocol, to match all cars 96-2017, signalling levels.. (OBD2 is complex in this regard)
not chopped liver here.
its a joy to use.
Looks like I have studying to do as I haven't even addressed automating my BBQ yet
redux gas engines USA, under 14,000 lbs.
http://www.fixkick.com/ECU/ODB2/ALL_OBD.html
here are the dates, usa. obd, its all about smog, until 1996;
100%
the evolution (USA)
early 1975 Analog, EFI, VW had it, no puters at all. just analog, (think amplifiers and buffers the like,)
then digital carbs, (don't even think about it, forgetting is best practice here)
GM in 1981 had early digital EFI but is not federal regulated, at all its A GM idea, and others to, but are all PROPRIETARY.
. ALDL assembly line data link
then in 1988 Calif, laws mandate this first, for the near future. its only for smog, period. ever been to LA before then, you cant breath there at all, red eyes, chocking , bad.
most auto makers built to the CALIF regs, for OBD1, so they can sell to all 50 states. (saves money ) some cars had some calif only sensors, silly this is,,, totally, like 3 and 4 wire o2 senors. yes, silly.
there magic here, nobody knew the futures, ABS ,Air bags, EPS, et cetra, (not invented yet) nor was it a topic then, only choking on the air mattered,,
but OBD1 is only for smog, yes they wanted makers to put in digital comms of some type (not a standard yet) to get failure codes. there is no standard yet ! No standard tools, but some makers of tools had plugins that allowed one tool to fit many cars (complex it is)
in the year, December 7, 1995., finalized all EPA rules on OBD2,(our invention )
The 1996 model years are mandated, now.
It covers smog. (goals)
and communications using federal P0 codes. only. IT is now a standand, one tool even for $10 works. (like the ELM 327 chip based tools work)
It does not cover, ABS , nor AIR BAGS nor any future magic.
how could it.?
we do have over regs, endless. but not scan tool rules.
The car makers have in fact added vast number of DTC codes. and live data modes.
If you need that , then you must buy it from any of 100s of tool makers.
talk to them. its there job to address your needs.
So here we are obd2, stilll in 2017
and the electronics on cars have exploded.
for 2 reasons.
customer wants toys, endless bs toys.
and the maker wants to lower costs.
so they use a power PCM/BCM /TCM to do all that, and with there OWN unique advanced PIDS and DTCs. P1, P2 and p3 and lots more.
they are way far beyond the meager needs of OBD2 now its not funny.
ABS
Air bags
EPS
talking cars. (Cortana like)
computer based, HVAC, controls and thermostats that read body heat. yah
U-connect bs.
heated seats.
electric seat up ,down, back and tilted.
electric windows.
Thief and security laws too, for IMMO.
Can-bus run radio and silly steering wheel buttons. and super complex, clock spring to match, yah., mines recalled. dang.
electronic free cruise, its just software, with TBW
throttle by wire to avoid that nasty 1 billion dollar Toyota lawsuit, (from silly floor mats btw) and 4 , count them 4 TPS sensors;...
and more, lots more.
and guess what?,DTC fed , P0xxx codes do not cut it now,..
the world has advanced.
so charge your customers for the tool, (amortized costs, passed on) like all do, now....
and select tools with great care.
They think now rich you will get , fixing talking cars and U-connect bs..... fixing those expensive toys,,,,,
Yes, I missed all that. Until 2011, I only ran pre 1981, non computer cars. After the rusting roof and windshield frame were allowing too much rain in, I sold the car.
it's best to miss it ,its a blessing. !!!
OBD is a pain if working on all cars. all makes,
sure is.
and takes hard work to be ready.
best is to get the book on your car
the real service manual
got that?
here where I live almost no 90s cars on the road, 95 back.
for vast reasons
but the top reason is , $2000 rebuilt a/t box. so car are scrapped. easy for that.
have you seen this?
https://suzukipitstopplus.com/Category/3...nuals.aspx
the real books, not fake, not store rags.
the real deal there
I have the paper manuals for the 96 Tracker, but I prefer it on the computer . The GM automatic transmissions, like TH350, TH400 can be re-done without any special tools. It's a bit difficult to unload the springs on the clutch pack all the way in the back, but it can be done without the special tool. The last one I did,
the previous re builder did a nearly perfect job, except for the last step. Before closing the whole thing up, the pump to case gasket went in upside down.
