ouch that took over 10tons of force.
well they are not so easy to find, (new or used, or upgraded)
suzuki sells them new, only you wont like the price. is this about cost?
im not sure the upgrade works. I have ever tired it , the one poster here that try this never reported back so.... hands in air. there.
every thing i know on this topic is here.
http://fixkick.com/hubs/FW_BEARINGS.html
the other post here, we found that ACDelco stopped making them... 89-98 years. ended
if you go to rockauto.com the are non there. sure the 2001 and newer 2006 generations are there.
facts,
GEO changed to 2001 hubs in a different year, making match ups harder near the years 2000.... yup a pain, for those years only.
same p/n 89-95, , changed in 96 to allow ABS ring and new axles/spline counts.
GM may have it ,did you ask GM/ (GEO) this.
Suzuki # 43421-60a00 is the correct part. (same part left and right) same part 2wd/4wd/2door and 4door. {no ABS yet} (lucky you, and did not say)
$188 at suzuki now. (I do not have the GM partnumbers now)
so not so rare, just the aftermarket hates susuzki's this old. it is and under dog car, after all,
here is an ADD to cart link, not sure if this works. but...
https://www.suzukicarparts.com
car-parts.com (autowreckers networks)
have parts used.
they dont have front wheel bearing hub as a choice. so not too good to search.
http://car-part.com/cgi-bin/search.cgi
upgrade (if possible) why not buy one and see if it fits. (I would have, in this case then took it back if not fit)
there is no other-way, but other forums have discussed this
ebay, i see no hubs, now, (usa) era correct. (early)
advanced Auto shows AW413, then says may not fit. not only that those parts are NOS< new old stock, ACDelco stopped making this part.
Im in the ACdelco master catalog, there is no such parts, FW at all.
they also made FW252 and 253s, for susuzu too, for some years, no idea the match up lacking old catalogs but they did, (DID)
ACdelco now uses new partnumber( yes, more madeness)
If i look in the book with due care , i learned that the hubs ended before 2001, both GM(geo) and sidekicks Suzuki, so there is no tracking this, lacking old books from them. (I dont have GM)
FW252 was the match I think,... back when. 253's for ABS.
so try them you tell us, be the first?
original.
![[Image: hub-with-races.jpg]](http://www.fixkick.com/hubs/hub-with-races.jpg)
2001(suz first year)
