01-14-2017, 06:54 AM
Hi,
1994 Sidekick 16v swap to Samurai...check eng light stays on and I get error code 22 (TPS circuit low V, Tp pin, not idle)...did a TPS check everything is good...i back prove pin 1 and 3 ignition on and I get 1v...check ohms pin 1 and 3 at idle is 1k full throttle 4.5k seems like everything is right order...still couldn't get rid of code 22..i did reset the ECU couple times at no luck..can anyone help...pls. thanks
BTW idle is good doesn't surge stays very steady...the car runs great has a lot of power..
