that is super good.
nice engine.
(08-31-2018, 02:15 AM)Heady Wrote: Compression test is done compression is as followed
1-165
2-170
3-175
4-175
I’m at 719 feet according to google. for some reason I’m really surprised my results were that good....on another note I just finished swapping my engine, tranny, and t case over to my doner 95 Geo. Other than an ISC (and coolant/vacuum line ran to it), dizzy, and ECU I should be good to hook right? I know the axles gotta come with the tranny from the old car, and I think the case pigtail too? Oh and speedo cable and speedo....that’s all I can think of. Doner car was an 8 valve as well just a 2wd so I have to steal my driver side mount off my 89 sidekick.
1989 Suzuki Sidekick, 1.6L, 8V, 4wd, 2 Door, Covertible, fiberglass top or rag top
1995 Geo Tracker, 1.6L, 8V, 2wd, 2 Door, Covertible, Parts Car..worth every penny
I’ll keep you posted how it runs when my parts come in. I’ve ordered an ECU, ISC, Dizzy, MAP sensor, and 10 foot of vacuum hose. If I need anymore please let me know lol.
One thing I’m concerned about is where do the coolant lines for the ISC come from? I’ll already be replacing all of the vacuum and small coolant lines so it shouldn’t be a huge deal to maybe throw a T fitting or route a new line should it? I’ve looked the site over and can’t seem to find where they come from or where the fresh air line leads to. I think this may be one of my problems I run into when I button the engine up.
On another note I have to tighten a few bolts up on the passenger front and re connect my suspension on the driver front, throw the wheels back on front side and the body mount rubber of course and the only thing left will be putting seats back in and fixing up the inside plastics.
By the way I’ve changed gear oil in the rear dif, going to change the front dif out, and ordered the specific part number GL4 synchromesh oil for tranny and tcase, so I shouldn’t have any problems out of those. I will have to send pics before and after when I’m done.
(09-07-2018, 02:23 PM)Heady Wrote: i forget are you trying to do , to mix parts from 95 to 89....?? not good that, in most cases.
89 is gen1 car, 95 is gen 2. (8v)
why do you need ECU is your missing? I thought you had a 89 ecu?
yes a rebuilt dizzy is always a good idea on any old 89/90 the VR+ignitor insides loves to fail as does vacuum advance and the centrifugal advance jams.
89 has no ISC coolant lines, it has 2 wires to the ISC , and now water (water heated ISC started in year 91) the heat is actually TB heat, the ISC never uses the water heat at all.
http://fixkick.com/sensors/89/89-TB-exploded1.jpg
the IAC in the TB is water heated on all cars.
89 cars have many unique parts, per my 89 differences page.
manifold intake
TB is not same nor is it's injector the same. gen1 to gen2.
the GEn1 TB also has no idle air bleed screw and has difficult idle duty cycle setting rules, cured in 91 year.
ECU unique.(gen1 to gen2, and endless smog differences, but forget that if not smog tested)
harnesses not same!
water hoses not the same. the 89 gen1, even has odd heater for PCV as seen here :::::: http://fixkick.com/sensors/89/89-throttlebody.jpg
distributor radically different in 91 due to ECU now does all spark and all advance, totally all ECU done now starting in 1991.
ISC not the same.
IAC looks same but TB is not same, so.... TB wins. always. do not mix TB years. gen1 to gen2 or up.
heads are different, the gen1 runs old distributor and gear drive, not sure if cam is different, on gear but housing is different.
I’ve looked the site over and can’t seem to find where they come from or where the fresh air line leads to. Air intake is super simple on all 8v, there is no MAF here.
gl5 in axles only
if using wrong GL in gear box 5sp, it only shifts super hard. for sure down shifting, best is lube marked as syncromesh, and hard to find yes.
Yeah I had to order my gl4 lube from California still waiting on it.
I’m trying to take my 89 8 valve with 5 speed tranny and tcase and put it into a 95 body and frame my 89 ecu wouldn’t work I’m keeping all of the 95 wiring so switching sensors and junk
(09-13-2018, 08:10 AM)Heady Wrote: Yeah I had to order my gl4 lube from California still waiting on it.
I’m trying to take my 89 8 valve with 5 speed tranny and tcase and put it into a 95 body and frame my 89 ecu wouldn’t work I’m keeping all of the 95 wiring so switching sensors and junk ok the only big problem is the distributor is not the same nor the harness for Distrb nor can the 95 ECU work on any 89/90 distrib.
the issues are 89/cam gear, 89 cam rear distrib housing and and 89 distrib, and then harness are not the same nor ECU.
I am not sure how to modify the 89 heat to fit 91-95 distribs. at all (ive forgotten this path, after 10 years) I think the heads are different at the 90 to 91 year change.
the 91-95 ECU will not like running any 89/90 ISC valve, due to 2 times greater currents needed there. Best is run the 92-95, TB only with that newer ECU.
The injector is not the same so there is 2 reasons not to use 89/90 TB.
that is easy things, TB , intake, the cam gear is a more serious matter.
I will see what i can dig up on cam gears today.
cheers.
ok heads match up dash 61a00 all 89/95 years. G16a 8v.
housing in the rear, same. -60aoo , very good news that.
cam is 3 P/N different, 60a00, 56b00(91) then 61a00 (92)
the suzuki Parts list does not show the gear as separate part.
but if you buy a head from china today, (cloned) it has no gear, and you get to take yours off and put it on there cam. (so if yours comes off ?)
but id check this 13 tooth gear and see if it matches up, to 91+ 89/90 gear fits 95 distrib.
Suzuki does not tell us why the cam changes, (be it profile changes (smog) or gear or both)
sorry i have never mixed parts 80 up.
the first crank shafts 8v are missing balance lobes so avoid those.
good luck to you and your engine swaps.
